Question about Pioneer FH-X700BT
Radio will not turn on
Do i need to purchase a wiring harness to install this radio in a 2006 pontiac grand prix
3 Suggested Answers
  • 3 Answers
SOURCE: avh-p6400cd indash radio
With this specific Pioneer model you need a brain for it ti function. You will be spending a good amount of money on all of the cords and brain. If you would like to do that, go to www.pioneerelectronics.com and type in your model number. every cord and accessory you will need will be listed there. This specific model has an optional navigation and tv tuner. Also for RCA outputs you will need another harness.
Posted on Feb 04, 2008
  • 24 Answers
SOURCE: i cant find a wiring diagram to install my new
Operation and Installation Manual: http://akamaipix.crutchfield.com/Manuals/130/130AVHP400.PDF
Posted on Sep 17, 2009
I have a 2005 pontiac grand prix. I just bought an after market radio. I don't know the what the wires do in the stock wiring harness. i can't figure out which color wire did what function
Well you can start by checking the wires behind the speakers. There are almost certainly 8 of those. Then there is a power wire which ought to be red and a heavier gauge, plus a ground, which should be black.
Or you can just refer to this wiring diagram :>)
2005 Pontiac Grand Prix Car Radio Install Instructions ModifiedLife com
Nov 23, 2016 | 2005 Pontiac Grand Prix
What fuses under the hood affect the radio in a 2006 Pontiac grand Prix?
Bradley, Radio fuse on interior fuse panel marked Radio/Amp is the only fuse I can find in your manual pg. 5-113. This is not to say the radio could be possibly tied into another circuit, so if you can test/probe all the fuses with a test light or DVOM and verify they are all OK and you can also check for power at the radio plug to verify weather it is getting power to radio.
Check the attached link manual. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.vadengmpp.com/owners-manual/pontiac/2006-Pontiac-GrandPrix.pdf
How to Test and Replace Car Fuse Like Pro
Checking Fuses Using test light
Aug 27, 2016 | 2006 Pontiac Grand Prix
I need a wiring harness diagram for 2006 Pontiac Grand Prix base model stereo system
http://www.modifiedlife.com/2006-pontiac-grand-prix-factory-stereo-install-diagram/
May 25, 2015 | 2006 Pontiac Grand Prix
I Need The Radio Code To A Pontaic Grand Prix 2004
be aware that if you change the radio to aftermarket you NEED the special adapter harness, you CANNOT just splice things together ..all kinds of stuff runs through the radio on these cars, it wont even start after if you do that
May 25, 2014 | 1998 Pontiac Grand Prix
In cold weather, clock on radio resets and radio cuts on and off
It sounds like your not getting a good connection to your battery. I would try replacing the wiring harness first, (remove radio to gain access.)
Apr 04, 2013 | 2006 Pontiac Grand Prix
1997 grand prix 4 door radio wiring diagram
Go to your local dealership repair shop. They can scan a copy for you. It will make it all very easy when you have the wire colors and circuit description.
Jul 22, 2012 | Cars & Trucks
Which color is the radio hot wire on a 2005 grand prix
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Run a wire from the back of the radio to the steering column or fuse box for a switched power source.
Feb 09, 2012 | Pontiac Grand Am Cars & Trucks
Need radio wiring diagram for 2000 pontiac grand prix factory diagram
2000 Pontiac Grand Prix Car Stereo Wiring Guide
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Sep 17, 2009 | 2000 Pontiac Grand Prix
CB Radio in a 2007 Pontaic Grand Prix
Easy to hardwire. Run the ground wire to anything metal under the dash, the power wire can be tapped into any fuse in the fusebox with a small adaptor available at any auto supply store.
Jul 02, 2009 | 2007 Pontiac Grand Prix GXP Sedan
I want to install a stereo in a 2001 grand am se but the wires were cut.
Here are the wires colors of the harness and what they do.
2001 Pontiac Grand Am Car Audio Wiring Diagram
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Mounted behind trim in the left side of the trunk.
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Location: N/A
May 30, 2009 | 2001 Pontiac Grand Am SE
Pioneer FH-X700BT Logo
52 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
