Question about Philips 42PFL7422D 42 in. LCD TV
Philips 55pfl5505d/f7 lines
I have small black horazonal lines across the screen its like every other horazonal pix. line is black. the forther you r away from tv the less u notice it.even when u go to menu itsstill the. its not anything thats hucked up to the tv.on the loading screen its there.
SOURCE: Small flickering green line on my lcd screen.
I had the same problem, and I just updated the tv's drivers to the new 1.15 version. I don't see the green anymore.
Posted on Mar 20, 2009
  • 10 Answers
SOURCE: 2 black lines on 42" philips flat tv
i can save you a trip to service center its not the x sus its your display or ribbons to display most likley display you can try to take off back and you will see ribbons on top or bottom of display try to gently press where screen is black if the screen fills in its connections on ribbons if not its your display cost prohibitve to repair sorry
Posted on Aug 12, 2009
  • 231 Answers
SOURCE: I have a Philips plasma 42 with black lines across the screen
I would first check if there is an available firmware upgrade for your model .Upgrade requires you to download firmware from philips website.Then transfer it to a memory stick .Then use a memory stick reader to plug into tv for firmware upgrade.Other wise the set would probably need repair .Possible a bad SSB board or another issue
Posted on Aug 26, 2009
  • 5 Answers
SOURCE: 32" philips flat crt PINK SCREEN
The set has detected a problem internally and does not "start" to precvent further damage. i would take it where you got it sweety
Posted on Sep 05, 2009
  • 31 Answers
SOURCE: black vertical lines across the full screen on
Hey mate, very common in all makes of plasma TV's. See this how to video on to fix it, the video is for a hyundia but it is the same for your TV. http://www.youtube.com/watch?v=9NPobj0_GSo
It's pretty easy, just get a soldering iron and take your time, best of luck. Bro
Posted on Apr 04, 2010
How to fix horizontal lines across whole screen on my Philips TV model# 52PFL7403D/F7?
The standard way to find out whether the issues on a tv are hardware related or settings environment related is to perform a reset to factory default through the menus available from the remote controlIf the fault persists after a reset and rescan the fault is almost certainly hardware related and will need the attention of a competent technician
Jul 03, 2015 | Philips Televison & Video
Phillips tv wont turn
Go to Philips web site, (enter Model number....) then download updated software & drive to update your TV software. It will fix that problem. I just did for my TV (42PF7320A/37).
Here is the link:
Download and save in USB. Stick USB on the TV' USB then updated from there.
Hope, It will work. Good look!
Nov 07, 2013 | Televison & Video
Philips 47pfl7403d/f7 LCD TV When the TV is
first you may check the T-CON board if thats ok then the problem is coming from your set panel .
Sep 01, 2013 | Philips Televison & Video
My phillips 2006 hd tv has a black line across the screen with a snowy freeze
If you have parallel horizontal black lines on a white background, you can see the separation between the lines when it is viewed at close range (Figure 1). As you view the lines from further and further away,the image gets smaller, you eventually get to the point where you can no longer see the separation between the lines, and it looks like one line. Losing the ability to see separation in the lines is exactly what happens when you sit too far back from an HDTV set. If we apply the same principle to an HDTV, a 1080p resolution HDTV has to fit 1920 vertical and 1080 and horizontal black lines separated by the white space on the screen, (that is the pixel grid of a 1080p HDTV display). Furthermore the spaces between each cell of the grid need to be very small in relation to the area each cell occupies, or you will get a screen door type effect. A bigger HDTV can increase the size of the cells and the separation between the cells, so everything doesn't run together when you sit further back.
Performance chip
May 22, 2012 | Philips Televison & Video
My screen has blue and red lines across it. Now the red lines are becoming stronger and the screen flashes red until it turns off. how do i fix this?
This is for if the lines are thin and in the form of an arc across the screen.
You need to turn down the screen voltage for the blue and red CRT. I believe the access is through the front on that model.
1) Remove the front grill
2) There should be access panel you need to remove once you remove the front grill. This is where the screen voltage adjustment is located
3) Look for a small black box with six knobs on it. One row is for "Focus" and one row is for "screen". It will be marked, but probably need a flashlight to see which row it is. There will be a "R", "G" and "B" next to each knob to represent Red, Green Blue respectively.
4) Careful with the access panel removed, you are only inches away from very dangerous voltages.
5) slowly turn the R or B knob counterclockwise until the lines on the screen disappear.
Keep your hands away from everything else and only use one hand near the tv. put the other hand behind your back.
6) Once corrected, replace the panel and put the grill cover back on.
Feb 19, 2011 | Sony KP-57WS500 57" Rear Projection...
Toshiba 27A40 has single colored line across enter
Vertical output has cracked soldering. Around $150 to fix.
May 01, 2010 | Toshiba 32A33 32" TV
Red lines across the screen. Small area works fine
You are going to need a new panel (screen).
Wish I could be of more help to you but there is no help for this one.
Aug 09, 2009 | Philips Televison & Video
Philips 42PFL7422D 42 in. LCD TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
