Question about Miele Washing Machines
W1712 will not turn on
Have just moved house, just plugged the washing machine in and it will not start
  • 221 Answers
SOURCE: No hot water after move for washing machine
Check to make sure the hot and cold water tap is turned on at the back of the washing machine, if there both on and working the water inlet valve could be defective.
Posted on Apr 08, 2009
  • 53 Answers
SOURCE: Candy GO1482 washing machine blows house fuse
This sounds like an electrical fault within your Candy washing machine.
Have you tried plugging your coffee machine, dishwasher or toaster into the SAME POWER SOCKET?
If so, does this still trip out the mains/house fuse?
If it does, it sounds like there is a fault in your house wiring.
If these "high power" devices/appliances do not cause the same problem, then you may have an Earth Leakage fault on your washing machine or something else inside it has short-circuited and will need servicing right away!
Posted on Nov 18, 2009
  • 4 Answers
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Posted on Dec 04, 2009
  • 177 Answers
SOURCE: can't get filter out of miele washing machine.
this should just unscrew anti-clockwise. it is probably just tight
Posted on Aug 18, 2010
pctech1
  • 1940 Answers
SOURCE: Lost the operating instructions for W1712 washing
Here are the operating instructions for your Miele W1712 Washing Machine:
http://www.4shared.com/document/3kzmRytc/Miele_W1712_Operating_Instruct.html
These instructions are in PDF format which requires the Free Adobe Reader Application, available for download here:
http://get.adobe.com/reader/
Posted on May 02, 2011
Does W1712 have an internal fuse? My machine has lost power despite the outlet being functional...
Hi dear,
Your machine does not have a replaceable fuse. If you are in AUS P/N:7790772 - Power-/Control unit EDPL 200-KD220-240Vse. I can advise to check part number with Miele, providing your machines serial number. I hope that helps. Thanks.
Feb 20, 2016 | Miele Washing Machines
Miele w1712 did not work...the machine was buzzer and when i saw it, it said waterproof fault
Hi dear,
There is a internal leak on your machine. You need to contact Miele to assist you. Thanks.
Jan 05, 2016 | Miele Washing Machines
Miele W1712 honeycomb care front loader the door will not unlock after cycle has finished, it has been 24 hrs
Try unplugging the washer's electrical connection, wait for about 20 seconds then plug back in. See if that resets your cycle to Start mode from an unfinished mode. If not, see if you start another cycle, such as a spin to complete any draining of water. It might have blockage that is keeping the water from draining thus thinking the cycle is not over - or- a bad sensor not telling the computer that the cycle is over and it's OK to release the door lock.
Nov 24, 2014 | Washing Machines
Hi there, I've just moved house, I tried to use my MW511 fisher and paykel washing machine. I plugged it in turned it on, it started to work as per usual. A few mins later it stopped. No lights are showing...
Hi Melissa,
Many things could have happened prior to your current problem. You moved house, how was your machine moved? How did you test to prove the wall plug is working? NO LIGHTS mean power is not flowing to your machine. I suggest you consider a proper check and service rather than trying anything on your own, unless someone is willing to provide a full specs on diognastics.
Oct 08, 2014 | Washing Machines
Apr 08, 2009 | Bosch Washing Machines
Can't get filter out of miele washing machine.
Dec 29, 2008 | Miele Novotronic Premier 500 Front Load...
Miele W1712 washing machine drain fault
Apr 05, 2008 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
