Question about Sony SPP A973 Cordless Phone
Cordless phone says out of range or no power at base although both not true. Phones replaced with no change. Corded phone works fine
    Master:
  • Sony Master
  • 465 Answers
It is the best of it's kind.. And it works flawlessly with my device Samsung J7... Only one problem. The shortcut feature always interfere with gallery, keyboard and few games.. But yes I admire LEO Privacy's designing and programming... LEO Privacy Applock Hide Safe Android Apps on Google Play
Posted on Sep 21, 2016
2 Suggested Answers
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
My display on my cordless/corded Phone won't light up. The cordless ones say out of range, or Searching. What can I do?
Is it the base display that won't light up? Can you make a call from the base? do you get a dial tone on the base?
Remove all batteries and unplug it all. Leave it sit for a few minutes. If that does not do anything, then it likely needs repair.
If the base makes a call, but cordless doesn't work, then likley the rf radio is damage by static from the storm.
Oct 04, 2014 | Motorola Mobility L702C DECT 6.0 Digital...
We have 2 Vtech cordless phones -a 6.0 and a 5.8 I don't think either work when the power goes off. Can't even phone the Power co.. Is this normal ?
Yes, that is normal for all cordless phones. they are really just a radio that sends a signal from the base/charger to the cordless hand set. when the power goes off the base does not work at all. Go buy yourself a cheap corded phone, and when power goes off plug it into any wall phone jack and then you can make calls.
Apr 04, 2011 | Vtech DECT 6.0 Digital Cordless Phone
Can I connect a CL82409 handset to a CL82409 base system
Yes, and no.
When you buy the new corded base station (CL84109) with 1 handset, that base unit by default is "paired" with only the 1 cordless handset that came with it.
While you can plug both base stations into the landline wall plugs (RJ-11), and when the line rings, both base unit phones will ring and will each operate as independent corded phones would.
But, in this scenario, the cordless phones communicate only through the base unit they are Paired with. The cordless phone paired with the CL84109 corded base unit will not be able to transfer or Intercom between the cordless phones paired with the CL82409 base unit.
However, if you want to transfer the cordless phones that originally came with the CL82409 base unit to work directly with the CL84109 corded base unit, you can likely "Pair" them to work directly with the CL84109 corded base unit for a total of 5 cordless phones to be paired to the CL84109 base unit.
Consult the User Guide that came with the CL84109 base unit for instructions on how to Pair additional cordless phoned to this base unit.
The CL84109 can be expanded and paired with up to 12 cordless phones. So, this should be do-able.
Keeping in mind that the CL82409 will no longer have any phones paired to it and will thus be useless from that point on. (unless you pair more expansion cordless phones to it again)
Mar 13, 2011 | AT&T CL82409 Cordless Phone
My uniden dect 6.0 model# 2088 base doesn't display anything and the handset says out of range
disconnect the battry and the phone like from the base and the phone(s) and them put them back together and see if it works.
Mar 12, 2010 | Uniden DECT-2088-2 1.9 GHz Twin 1-Line...
Hand set out of range disply is on. How do I reset.
here are some tips from my manual for out of range problems
hope they help
• Only one handset can be used to make or answer a call anytime.
If another handset attempt to do so, the screen will display OTHER
HANDSET ON and then OR OUT OF RANGE. You might press PHONE
or SPEAKER again until no other handset is using the line. Use the call
transfer feature to transfer a call to another system handset
or use the speakerphone feature so multiple members of your
house can be on an active call at the same time.
• Move the cordless handset closer to the base. You might have moved
out of range.
• Ensure that the base is powered up.
• Place the cordless handset in base cradle for 1 minute to allow the
cordless handset and base to resynchronize channels.
• If the cordless handset is in its base and the charging light does not
come on, refer to the charge light is off in troubleshooting guide.
• Reset the base. Unplug the unit’s electrical power. Wait for 15 seconds
then plug it back in. Allow up to one minute for the cordless handset
and base to reset.
• Other electronic products can cause interference with your cordless
phone. Try installing your phone as far away from these types of elec
tronic devices as possible: wireless routers, radios, radio towers, page
towers, cell phones, intercoms, room monitors, televisions, personal
computers, kitchen appliances and cordless phones.
Jul 16, 2009 | GE 29897GE1 Corded Phone
Cordless phone 25881
Sounds like a power problem.
This model of phone will work as a regular corded phone when no ac power is available.
IE the cordless function is only available when you have electricity.
- is the ac adapter plugged into a working outlet.
- is the ac adapter working.
- is the ac adapter pluged into the base.
hope this helps
Nov 30, 2007 | GE 25881EE3 Phone
Out of range
I have a Radio Shack 2.4ghz cordless phone system and sometimes the handsets will show "Out of range".
My Solution that works for me.
Unplug the power cord and telephone line to the base for about 30 seconds. This seems to reset the base. Then plug everything back and you should be ok.
ET Sherman
Oct 07, 2007 | Panasonic KX-T7730 Corded Phone
Cordless phone does not connect
I have the very same problem and it was after storing numbers into the directory, although that may not have anything to do with it.
Jan 23, 2007 | AT&T E5908 Phone
Sony SPP A973 Cordless Phone Logo
Top Sony Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Lands Phone Expert? Answer questions, earn points and help others
