Question about Dryers
I have a model 110.97580100 (75801) heavy duty 80 series Gas dryer. It tumbles but there is no heat. Is this something I can fix myself? We checked the lint filter & Lint chute to see if there was blockage - there was none.
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You need a thermal fuse, very simple and affordable to replace. To replace the thermal fuse just remove back cover of dryer and look down where the air blows out. Now, just to the left where all the wires are you will see a white plastic part with two wires plugged into it. This part is called a thermal fuse. Just remove these wires and replace the thermal fuse. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
My malleys heavy duty 1050 wont tumble.
I could not find much info on your dryer, but there is probably a belt that goes from the motor and wraps around the drum. If the drum is not rotating, the belt may be broken.
May 26, 2014 | Whirlpool Dryers
Dryer is a Kenmore Heavy Duty 80 series electric. Runs fine but very little , and often, no heat. Is the element gone?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 20, 2010 | Dryers
I have a Kenmore 80 series gas dryer. Dryer heats
The belt around the drum has come off or broke. The front of your dryer will have to come off to inspect
Feb 04, 2010 | Dryers
80 Series Gas Dryer - No Heat. All other parts
check outside drye vent where it goes through the wall they clog up with lint sometimes and force the escaping warm air to back up which causes sensor to give wrong reading if this is clogged just clear it till you feel the air coming through also check vent at bottom of dryer disconnect flex pipe and check for clogs there as well ..and always clear lint trap after every load
Dec 13, 2009 | Kenmore Dryers
Kenmoore 80 series heavy duty (gas dyer) no heat.
If you still need help please post your model number. Gas/Electric?
Eric
May 25, 2009 | Kenmore 63942 Dryer
Kenmore 80 series runs but dont blow hot air
Where is the location of the heating element for a Kenmore 80 series dryer heavy duty model # 77834795
Dec 09, 2008 | Kenmore 63942 Dryer
Kenmore Heavy Duty Dryer 80 Series
It may be too late for you, but here it is. I had the same problem, took the dryer apart, and found that one of the rollers was broken. There are two plastic rollers at the bottom rear of the unit. Call around to local parts stores to see if they have this part. It's easy to fix, just takes all day because you have to completely dissasemble the dryer.
Sep 20, 2008 | Kenmore 63102 Electric Dryer
Kenmore 80 Series Model #110.74842400 Series MR5112733
There's a few things on this dryer that can stop it
from heating. 1st thing your going to need is an ohm meter, your testing simply for continuity. The main items that cause no heat at all on this gas dryer is the igniter on the gas valve, the thermal fuse located on the blower wheel housing the thermal cut out located on the burner box or the flame sensor on the burner funnel and lastly the coils on the gas valve. the sequence is from most too least common. Of course unplug it and shut the gas off.
Jul 30, 2008 | Dryers
Dryers Logo
95 people viewed this question
Top Dryers Experts
Marvin
Marvin
