Question about Dell Vostro Computers & Internet
Getting case fan error - Vostro Dell Computers & Internet
  • Dell Master
  • 15,557 Answers
What model is it? Could you post the service tag number?
Posted on Nov 06, 2015
FAN Failure
You need to disassemble case to access the cooling fan inside.
Get a replacement fan from Brother.
If desperate.,peel off the fan label and oil (using sewing machine oil) the fan spindle bush or bearings.
Reassemble.
Jul 24, 2014 | Brother HL-2270DW Wireless Mono Laser...
System fan error
If you have replaced the fan and you are still getting a "Fan Error" then you have replaced the wrong fan. The system fan is not fitted to the top of the processor, it is usually fitted to the case.
Sep 08, 2013 | HP Pavilion m8120n PC Desktop
New case fan running but still getting error message system fan failed.
Did you try;
Power off, power unplugged to computer.
Press the Power On button, and hold it in. Hold for a count of 10 seconds.
Let go.
Do this procedure two more times.
Plug the computer back into power. WAIT 1 minute, turn the computer on.
This method clears CMOS Error Codes, and sets BIOS Setup back to the factory default settings.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00864946&tmp_task=prodinfoCategory&cc=us&dlc=en&lang=en&lc=en&product=3340228#N436
CPU fan spinning at required minimum RPM's?
Not talking about the SYS_FAN (Case fan)
Regards,
joecoolvette
Jan 18, 2013 | HP Pavilion a1720n PC Desktop
Computer gets HOT and it gives me ERROR CODE CPU FAN ERROR?
Is the fan working? can you hear it? if the fan is working, check to see if dust is clogging the air vents on the side of the case, if there is, then there is probably alot of dust inside the laptop too. that may be whats causing the computer of overheat. , this is just one possible cause, the CPU fan may be broken, or your bios my be messed up.
Feb 03, 2011 | Averatec 3200 Notebook
I replaced the fan # 2 after getting that error on
Which fan did samsung say was fan #2 ? As from my experience dealing with Samsung they dont know the difference between the fans but fan 2 error is usually refering to the fan under the light engine in the L7 and the L6 its the small one in the gray plastic case which blows under the ballast.
Dec 09, 2009 | Samsung HL-S6188W 61" HDTV
Fan error problem
Sounds like the mother board thinks the processor fan isn't running at all, or not fast enough. Can you verify that the fan is running, by sound and the movement of air through the vents? If no fan/air movement then you should address that fan problem that your thinkpad has developed.
In case it's the fan and you decide to crack it open yourself? Let us know?
Sep 12, 2009 | IBM ThinkPad G41 Notebook
Case fan rpm problem, error msg on boot up
please try to replace the fan and after replacing it, reset the bios.
another way is to change the position of the fan's power source.
May 20, 2009 | Computers & Internet
System fan error
Just check that (1)you have installed the fan properly
(2)connected the supply to the fan correctly
(3) the fan is actually running when you switch on the PC.
also clear the dirt which has accumulated in the heat sink. While doing all this , ensure to use antistatic means.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Jan 25, 2009 | MSI RC410M-L Motherboard
Fan flow error 1611 I/O
Either the Case fan or the CPU fan has failed.  Replace it .
Your HP support site for you product below: G2, 3, 4, 5?
http://h20180.www2.hp.com/apps/Lookup?h_lang=en&h_cc=us&cc=us&h_page=hpcom&lang=en&h_client=S-A-R163-1&h_query=+Compaq+ProLiant+ML370&submit.x=4&sub
Jan 16, 2009 | HP Compaq ProLiant ML370 (102118-031)...
Fan Error
Please contact the supplier for support under warranty.
If not under warranty, do check the power for the fan, after opening the outer case
Please disconnect the main power before opening :)
Try to tell me.... whether my suggestion was useful???
Bye
Have a nice day.
Feb 06, 2008 | NEC MultiSync VT540G Multimedia Projector
Computers & Internet Logo
35 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
