Question about Whirlpool Inglis IP4400 Washer
Dryer will not start in most of the selected positions
    Sergeant:
    Champion:
  • 205 Answers
The selector switch or the timer may go wrong please check it
Posted on Jun 30, 2009
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
Servis washing machine
Just by the sound of it, it sounds like it is the door lock/ sensor
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 10, 2013 | Washing Machines
Dryer wont start
Hi firew34 - If the dryer will not allow you to operate, try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, control board or door switch.
May 03, 2013 | Frigidaire GLET1031FS Top Load Stacked...
All of a sudden dryer will not start
Hello Darryl Jay - I understand that the dryer will not start; however will the display illuminate or allow you to program a setting? If it will not allow you to do so, try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, control board or door switch.
Mar 16, 2013 | Frigidaire FEX831CS Top Load Stacked...
Dryer humms but doesn't actually run.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jul 03, 2010 | Hotpoint NVL333EY Electric Dryer
Kenmore dryer keeps on going and going
The timer is bad. It is located behind the knobs and can be replaced really easily. The price for a new timer is about 35 dollars. If this helped please rate
Feb 12, 2009 | Kenmore 64902 Electric Dryer
Doesn't stop
The problem is probably the plunger switch that you press to start the dryer. If you select the OFF position and then move the dial to a cycle, does it start running without you having to press the start button? If so, that switch is your problem.
If you disconnect the dryer and remove the rear panel, you can unplug the switch and repair it yourself (the contacts probably just need to be adjusted) or you can replace it. Depending on the dryer you might be able to get the part number from the inside cover of the rear panel.
Apr 17, 2008 | KitchenAid KEYS750LQ Electric Dryer
Error code DR
Pull the tech sheet out of the dryer ( behind the lower front access panal ). The lights flashing are trying to tell you a fault code.
A copy:
MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O’clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O’clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the START indicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
jeff.
__________________
http://www.applianceaid.com/
Appliance Repair Aid
http://www.jrappliance.ca
JRAppliance
Jan 10, 2008 | Frigidaire AEQ7000ES Dryer
Dryer Rack
On mine, nothing "clamps down". There are 3 positions in the plastic rack into which you can insert the wire rest - "F", "H", and "A". God knows what they mean (I think the one rack is intended to be used in various dryers, of different depths), but if I use the rearmost position = "A", the back end of the wire rest rests on the non-moving rear of the drum, and the front of the rack rests on the lint screen holder. Seems to work, but the instructions leave a lot to be desired.
Dec 09, 2007 | Kenmore Elite HE4 Electric Dryer
3 beeps mean what
If the only thing that happens is three rapid beeps when you select a feature from the console this is usually a symptom of a defective door switch.  The door switch must be closed to complete the circuit from the timer to the heating circuit and drive motor.  If the switch is bad, or the wiring is broken, the dryer will not run.
Oct 17, 2007 | Kenmore 62062 Electric Dryer
Whirlpool Inglis IP4400 Washer Logo
46 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
