Question about NRS Rock'em Sock'em Robots
How do i take apart the rocken sockem robots to fit in the box
Looking for a ring post replacement.
Looks like a similar ring set up as the one found on the Rockem Sockem Robots ring.
If you can't find one and assuming your problem is one of the posts broke you could always glue it back to the ring platform itself. Use a two part epoxy found at Lowe's or Home Depot. Tell them you need it and they'll show you where it is. To use a two part epoxy, all you have to do is mix the same amount of both gels into a paper cup and apply to both sides of the broken pieces.
I hope this helps. Good luck!
Dec 16, 2015 | Mattel WWE Elite Scale Wrestling Ring
Can I order replacement remotes? The red robot is a 49MHz and the blue robot is 27MHz.
sorry you have to contact the manufacturer . and we do not know who that was
Jun 29, 2015 | Toys
Incorrect parts from 3 in 1 robot transformer solar kit
call where you got the kit from and ask them what can be done
May 25, 2017 | Elenco Electronics Elenco OWI-MSK614 T3...
Hey i bought a RAD 1.0 robot and the remote doesnt make it do anything. the robot starts up and goes through a systems check and it does everything well by itself but will not do anything when i try on the...
I READ THAT THE HEAD HAS A MICROSWITCH THAT TELLS THE ROBOT THAT IT IS IN DRIVE MODE AND YOU NEED TO UNSTICK IT TO GET THE REMOTE TO WORK.
Nov 28, 2010 | Toys
Robot coupe 350 faulty switch how to dismantle
take out the side grills, and then remove the 4 screws (torax) remove the rubber covers (4) 4 on the handle, and also remove the screws...two shell parts come apart, and voila, there is the swich...good luck
Jul 20, 2010 | Robot Coupe MP 350 Turbo Combi Mixer
Robot runs for about 5 min. then says clean brushes. brushes do not turn
The dust build up in these Roomba's do create a problem in all operating phases
Keep in mind if taken apart every 6 months and cleaned inside they will operate like they should
Jul 03, 2010 | iRobot Roomba 560 Robotic Vacuum
My dirt devil Rampage Robotic pool cleaner vacuum get stuck on the bottom drains
There is a ring that is designed to fit over bottom drains to prevent robotic pool cleaners from getting stuck. There are several different brands/kinds available and any of them should prevent the problem. Here is one example:
http://www.backyardcitypools.com/Automatic-Pool-Cleaners/NE290-Smart-Ring-Drain-Cover.htm
May 07, 2010 | Dirt Devil Rampage Robotic Pool Cleaner...
Looking for spare parts for a Robot Coupe R301 Ultra Food Process
Robot-Coupe USA.com should be able to sell you anything needed
Jul 09, 2009 | Robot Coupe Food Processors
NRS Rock'em Sock'em Robots Logo
89 people viewed this question
Top NRS Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a NRS Toy Expert? Answer questions, earn points and help others
