Question about Dell Latitude D600 Notebook
I have a Dell Latitude D600.\r\n
When I try to boot from the cd (to start a ghost recovery) the cd-rom drive is not loaded and I get a "No CD-ROM drive to use; GCDROM not loaded! " and then:
Invalid drive specification
Bad command or file name
A:>
How can I get the cd driver to load so I can boot from the CD? I'm running Windows 2000 Professional.
  • 2 more comments
  • mary_prenave Jun 19, 2009
    I have gone into the boot menu via F12 and specified to boot from the CD. It then states:
    WARNING: - All data wil be erased when this process begins
    Back up any data before beginning recovery
    To terminate the recovery process press Ctl-C now,
    otherwise, press any key to proceed.
    Press any key to continue...
    A:\>
    I downloaded the new bios and burned it to a CD. I then put the CD in the D600, powered on, hit F12 to get into the boot menu and tell it to boot from the CD, and it ignored it and booted from the hard drive. Not sure what I did wrong.
    I updated the BIOS and I still have the same problem. It still thinks there is no CD ROM drive. Yet the disk spins, the light flashes, it sends a message to the screen saying a recovery is about to be done, backup all date, blah blah, then press any key to continue. Then I still get this:
    A:>
    Thanks - I'm going to try to get a new image to burn and try the recovery again. It's gotta be the image I have that is corrupt. Thanks for heping me make sure the pc was not the culprit.
  • 334 Answers
Have you changed the bios to boot from the cd rom 1st?
Posted on Jun 19, 2009
  • 2 more comments
  • seth veloso Jun 19, 2009
    You should be booting from drive D: for you cd rom, drive A: should be your floppy
    Hey, another thing to try is go to the following link
    http://support.dell.com/support/download...
    there is a download for a bios update that in part deals devices in the media bay are being reported incorrectly. I am guessing that you have a second computer and the deel is not working. You can download the new bios file, burn it as an image to a cd, put the cd into the Dell, press F2 to enter bios and change boot order, boot from cd rom, then it should update its bios, when doing, put your ghosting cd back in and give it a try
    let me know
    did you burn the cd as an image file? You want to press F2 not F12.
    Well, if it is starting to recover then stops, it sounds to be like maybe the cd is scratched, your lens is dirty, or the files are maybe corrupted on the disk. Your mobo does seem to be looking at the cd drive, its whats in the cd drive that's bad.
Cant read my dell latitude d600 cd-rom driver
try a firmware update from official dell website if your drive is not knackered...
Jan 02, 2011 | Dell Latitude D600 Notebook
I need a resore disk for latitude d400. Windows XP will not load. continues to go through start up procedure.
You can try to press Ctrl key + F11 on boot-up if you have a recovery partition on the computer it will take you to the system recovery options and from their you can select dell factory image restore that will restore your computer to factory settings but you will loose all your data. If their is no recovery partition then you can call dell to Oder a recovery cd that will cost you $10 to $12.
Mar 14, 2010 | Dell LATITUDE D400 D500 D505 D600 D800...
Dell D600 cd rom replacement instructions
There should be a screw on the bottom holding the cd rom in place. Unscrew the screw and then with one end of a paper clip put it in the small hole on the front of the cd rom and the door should open. Now go ahead and pull the cd-rom out.
Now you can go ahead and put the new cd-rom in place and put the screw in and then turn on the laptop and let it boot up into windows and windows might redetect it. Go into my computer and you should see your cd-rom in there.
Jan 23, 2010 | Dell Latitude D600: Pentium M 1.6GHz,...
Error code unmountable_boot_volume and it wont let me go into safe mode
Could also be a hard drive issue. Try going to the BIOS and look for the Drive category. Look for SATA Operations and change it to ATA. Save the changes, then exit the BIOS,
Running the Dell diagnostics on the hard drive wll also be a good idea. Turn off the system and then hold down the FN key, then press the power button. This should start the computer and initiate the diagnostics test which should check the hard disk and memory for errors.
Oct 16, 2009 | Dell Latitude D600 Notebook
Dell "Drivers and Utilities" CD
Hi, the "No Diagnostic Utility Partition Found" is returned because your laptop does not find the recovery partition on C drive.
Easiest way to create partition is with dell recovery cd. You can buy CDs from dell, buy finding contact on web site or buy from one of the following.
Dell Restore Disk: XP Pro SP2 for ... $35.00 - DIMOSOL - Digital ...
Dell Latitude D600 XP System Recovery CD ... $18.95 - recovery-cds.com ...
Dell Latitude D600 Vista System Recovery ... $18.95 - recovery-cds.com ...
Buy recovery cd according to windows version on sticker at the back of your laptop.
With recovery CD you wont need drivers.
Alternative solution is downloading drivers posted by Maanita after installing Windows from a generic Windows setup CD.
Aug 13, 2008 | Dell Latitude D600 Notebook
My dell d600
NTLDR or NTDETECT Is Missing or Corrupt Error Message
Table of Contents secondary.gif Start the Recovery Console secondary.gif Repair the Missing NTLDR or NTDETECT File » Start the Recovery Console
  1. Insert the Windows XP CD into the CD or DVD drive.
  2. Restart the computer.
  3. While the computer is starting, repeatedly press F12 every 3 seconds to access the one-time boot menu.
  4. When the one-time boot menu appears, press the Down Arrow to highlight the CD-ROM option that appears, which is one of the following options: Onboard CD-ROM Drive or Onboard USB CD-ROM Drive.
  5. Press Enter.
  6. When the computer boots to the CD-ROM drive, press R to enter the Recovery Console.
» Repair the Missing NTLDR or NTDETECT File
  1. Boot the system to the Windows XP Recovery Console.
  2. Type map, and press <Enter>. Make note of the drive letter assigned to the optical (DVD or CD-ROM) drive.
  3. Type copy x:\i386\ntldr c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  4. Type copy x:\i386\ntdetect.com c:\ (where x is the drive letter for the optical drive), and press <Enter>.
  5. If you are prompted to overwrite the file, type y, and press <Enter>.
  6. Type exit and press <Enter>.
  7. As the computer restarts, remove the Windows XP CD.
The files have been restored and the error message should be fixed.
You can check this website for further details.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&cs=19&l=en&s=dhs&docid=B93824605BF646F98FDFACA51E3A9B55&journalid=4F6F8BC06C3B5014E040AE0AB5E121D2&Query=TlRMRFIraXMrbWlzc2luZw==&SystemID=LAT_PNT_PM_D600&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Pls let me know asap if we did resolve it.
Dont forget to rate me Fixya....
Cheers.
Jun 15, 2008 | Dell Latitude D600 Notebook
Doesn't boot but i see the windows xx installation
Use ur xp cd and try repairing ... use the FIXBOOT command in the recovery console .... Not to worry much its just the boot.ini file which has corrupted ..
Dec 24, 2007 | Dell Latitude D600 Notebook
Dell Latitude D600 Notebook Logo
60 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
