Question about Toshiba TLP-XD2000U Mobile Projector
My toshiba projector keeps shutting off after 15 min ?
Sometimes it will stay on longer ..but not recently ..i clean the dust filter....... it does seem to be overheating i guess..does it need a new bulb??? or some servicing
  • 2,237 Answers
Clean out the projector with canned air. if it still happens, you'll need to replace the power supply.
Posted on Nov 11, 2009
It stays on for 15 or 20 mins then light goes out but sound still plays with light out,then 4mins later it comes back on
Sounds likely that the projector is overheating. Try removing and carefully cleaning the filters over the air inlets. Carefully washing them in warm water and squeezing dry is usually satisfactory, but DO NOT replace in the projector and turn on until the filters have had at least 10 - 12 hours to thoroughly dry out.
Mar 29, 2014 | Christie DS+60 Multimedia Projector
Gets hot shuts down its toshiba TDP-SP1 how can i resolve it?? do i need to change cooler?
Make sure filters are cleaned. Use a vacuum so you don't spread dust around inside your projector. Make sure the projector can "breathe"; has room around it.
Nov 04, 2013 | Toshiba Office Equipment & Supplies
Our projector turns on, plays movies, however 15
could be overheating, one of the fans may not be working, or the power supply is bad. i could better helpyou if i knew the make and model.
Mar 21, 2010 | Office Equipment & Supplies
The projector keeps overheating and shutting off. It'll be on for maybe an hour, and then it dies. Then we wait, turn it back on again, and it dies five-ten minutes later. There's a fan pointed at it,...
Check to see if there are any filters that can be cleaned. They are slim and hard to see sometimes but they would be in certain places where air flows into the projector, possibly on the sides or bottom. Remove the filter and blow on it to remove all the dust.
Jan 18, 2010 | Sanyo PLC XU35 Multimedia Projector
My Epson EMP-TW20 projector has consistantly started cutting out 20 mins after being turned on, it then switches to stand by and I think the fans go on for about 5 mins. However, if I switch it straight...
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
Nov 01, 2009 | Epson EMP-TW20 LCD Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
Loss of picture
Yes, it is the projector.
Take the filter out and vaccum it, take the lamp out and use compressed air to clean the dust away.
Be carefull witt the air thoug! keep it a bit away from the projector when u cleand the dust away, to close and you can make big mamages inside it.
And, remeber to keep the filter as cleas as possible, i clean min every 2,5-3 monthes.
Good luck
Dec 06, 2008 | Sanyo PLV-Z4 Multimedia Projectors
OPTOMA EP716
ALSO CHECK YOUR FAN. IF THE FAN OR A HEAT SINK IS NOT WORKING PROPERLY (I.E. THE FAN MAY JUST NEED TO BE CLEANED OR REPLACED, THERE SHOULD BE A SMALL HEAT SINK. IF CLOUDED W/DUST, IT WILL KEEP THE OPERATION SHORT). ALSO CHECK IF YOU HAVE SET ANY TEMPERATURE SHUTDOWN PARAMETERS. IF YOUR LAMP HEATS UP FOR SO LONG AND REACHES A TEMPERATURE THAT WILL AFFECT THE CIRCUITS, THIS OF COURSE WILL SHUT DOWN YOUR UNIT UNEXPECTEDLY. HOPE THIS HELPS...JGUAM
Jan 12, 2008 | Optoma EP716 Multimedia Projector
Infocus Lp290 Will not stay on.
Check the area around the fan and make sure you have good airflow. Put a small fan near the unit and direct the air flow so it cools it and let us know.
Aug 26, 2007 | InFocus LP290 1100 Lumen XGA LCD Projector...
Toshiba TLP-XD2000U Mobile Projector Logo
440 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
