Question about Jura Capresso Jura Ena 5 2Cup Coffee Maker
Water keeps dispensing on jura eno 5 - Jura Capresso Jura Ena 5 2Cup Coffee Maker
I cleaned my Jura Capresso with a tablet, but the message "Clean Machine/Ready" won't switch back to "Ready". Any suggestions?
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Oct 06, 2016 | Jura Capresso Impressa Coffee Makers &...
My Capresso s8's display is blinking and making strange noise
All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous:
1- When new machine is set up, the owners click OK for use of Filter cartridges. This helps only to display reminders for replacing the filter.
2- The instruction also advises, regular use of Filters, eliminates descaling the machine. That is not accurate. Reminders for descaling are delayed or eliminated. This allows accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura also leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate & pointing to descaling the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution & continue descaling the rest of the machine using hot water dispensing function, until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Sep 23, 2016 | Jura Capresso Impressa S8 Coffee Maker,...
My tray is filling with water and dry grounds are being dumped and no espresso is dispensing.
The passage of water is not passing through coffee grounds. The coffee powder is dumped dry & water is bypassing the brew group and draining into the tray.
Causes:
1- Machine was not descaled. or descaled with automatic method only, as suggested by Jura.
2- There is accumulation of Calcium in the hydraulic system, generating back pressure. This reduces the pump pressure and water cannot force its way through coffee grounds.
3- Stop using filter cartridges. Turn the reminders off.
Solution:
Descale machine manually every three months. See link. Services Unlimited Inc Parts Guru Since 1988
Sep 02, 2016 | Jura Capresso Impressa S9 Coffee...
How to control acidity problem in daily life?
As far as the control and cure for acidity is concerned, there are several medications available in the market for tackling the problem. ENO is definitely one of the most effective solutions to cure it with instant relief.
ENO Fruit Salt ENO Powder fights acidity fast by dissolving quickly in water to neutralize the acid in stomach. ENO Powder gets to work in just 6 seconds, so you can get back to life quicker and enjoy it.
Apr 20, 2016 | Health & Beauty
My Jura Impressa S9 does not GRIND?
Could be bad grinder or no 12v. The display/control runs on 5v and there is a transformer (supplying 5/12vdc) where the a/c cord comes in. Mine was blown from lightening.
Try these guys... they have parts, trouble shooting and videos on youtube.
http://www.partsguru.com/JuraCapressoImpressa.html
Jan 26, 2015 | Jura Capresso Impressa S9 Coffee...
Jura impressa z5 coffee machine is not dispensing coffee what is the problam
What sounds are coming out of the machine
1. When you switch on, does it rinse.
2. When you press for coffee does everything sound normal
3. Does it dispense hot water
Nov 13, 2014 | Coffee Makers & Espresso Machines
How do I unblock the coffee spout of the jura 5
My Jura 5 was only pouring coffee from one spout, the other was blocked. I fixed it by removing the cover from the spout (see photo) it clips off with pressure applied to the sides on the dimpled part, then removing the brown reservoir inside after disconnecting the brown tube. Right enough, one side of the reservoir was full of coffee residue. I cleaned this with hot water and a tooth brush before re-assembling it all. The machine now pours perfectly from both spouts.
Oct 02, 2014 | Jura Capresso Jura Ena 5 2Cup Coffee Maker
My Jura Impressa xs90 keeps stating fill system, even after filling the system several times for the last 3 days.
Empty the Water tank and fill it with warm water. Then keep trying for some time and the problem will get solved.
Oct 15, 2009 | Jura Capresso Impressa S9 Coffee...
Jura Capresso Jura Ena 5 2Cup Coffee Maker Logo
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
