Question about Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500
Only runs on full throttle
New spark plug, new tank of gas, new air filter but it only runs when set to full throttle setting. It starts on full throttle setting but if I move the setting to half throttle or run the motor dies.
thanks for any help you may give me
Dan
    Problem Solver:
  • 14 Answers
Are you saying full throttle, or full choke? if full throttle, you should be able to set the idle up. the idle screw will be the one when you give it gas, it will be the screw on you'r throttle linkage. If full choke, maybe the spark arrestor is plugged. You can remove it by removing the muffler.It would be between the muffler and cylinder head. You don't need this to run.I hope any thing I posted will help.
Posted on Jun 19, 2009
Craftsman Leaf Blower will only rev up about 1/2 power at full throttle. Any suggestions?
If this is a two cycle engine there are adjustment screws that set the fuel mixture when the throttle is depressed.
Dec 02, 2016 | Craftsman Garden
When weed eater is running in order to get the head to turn i've got to give it full throttle before i can cut the grass, and it still bogs down.
do you have two adjustment screws down in a hole in the carb?
If you do they are the carb. high and low adjustment.
What I do is take a hacksaw and cut a groove right in the housing an the screw heads .that way you can adjust them Good luck
Feb 07, 2015 | Troy Garden
My d100 will not start
Check for good , strong spark. Take spark plug out and ground the outer core of the plug to the engine. Hold the plug with a pair of insulated pliers. Have someone crank the engine while you observe for a good strong blue spark. If the spark looks nice and bluish, then next would be to clean the carburetor. I suggest trying a "quick clean before taking the carburetor bowl off. Take spray carburetor cleaner and spray inside the carb throat with the air cleaner off. Also take about 1/2 can/bottle of fuel line injection cleaner and put it in the gas tank. Then try starting the mower. May sure the gas in the tank is fresh.
Jun 20, 2014 | John Deere Garden
Craftsman YT 4000 Won't Start
Did you check for "spark" at the plug? Check fuel filter ( maybe plugged up ". How fresh is the gas?
Nov 10, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a pressure washer at work that has good spark and starts when I put gas in the carburetor.But it wont stay running. I have the gas turned on but it doesn't seem to be getting to the carb. It's...
Here is the long answer with everything we learned while using a power washer twice a day for years:: It covers the things you already tested, but doesn't hurt to repeat. Your problem is actually #8 on list below.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or machine would die. We still use machine at 2/3 throttle, and then start each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Nov 22, 2010 | Honda Pressure Washer PSI 3000
Motor has been sitting for a while changed out old gas put new in drained carb bowl put new spark plug wont stay running
Here is the long answer with everything we learned while using a power washer twice a week for years::
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
Now the nitty gritty: we're gonna start that thing right now
If engine will not fire and keep going on WD-40, then your spark is suspect.
Add a comment if you need more help
Nov 21, 2010 | Garden
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
Cannot start husq 340 have spark but no combustion even if put gas in spark plug hole. have new spark plug
The engine may be flooded--take the plug out, turn the saw upside down, and pull the starter rapidly a few times with the throttle full on. If flooded, a fuel spray will likely come out of the plug hole. Make sure the ignition is OFF when doing this--you don't need a fuel fire! Is the spark at the plug blue and snappy (plug gap set to 0.020")? Replace the plug and see if it will run. Make sure the air filter is clean. Hope this helps!
Oct 16, 2010 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My pressure washer is 3 years old, never had a problem with it until now. It runs for 2 seconds only on choke. It will not start or turnover at all with out the choke on. Please help, I miss my...
Now the nitty gritty of starting that bad boy and making you happy again!!!!
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week. Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal. If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Let us know how it comes out!!
Oct 15, 2010 | Honda Black Max 2600 PSI Pressure Washer
Press washer starts an runs for 5 min then shuts down/ restarts in a few min then shuts down again
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. The high-speed exhaust air must pass freely.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas, and then put in new gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Check small engine repair shop or auto parts store for gum out, and don't store engine with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way on the spark plug?
Oct 14, 2010 | Craftsman Garden
Poulan 25cc 2-Cycle Gas Powered String Trimmer #P2500 Logo
912 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
