Question about ViewSonic VFD1028W-11 - digital photo frame
Shows pictures on USB for a 15 minutes and then switches to internal sample pictures and does return to USB pics. Have to turn it off, reinsert USB and restart. Then it does it all over again.
Settings are set for current directory
How do i get pictures off internal memory onto a computer or sd card
Hi, I have the similar s8000fd and I transfer pics from internal memory by taking out the sd card then connect to a spare usb socket on computer, then switch camera on. To transfer pics from internal memory to sd card - leave sd card in, switch on camera (playback mode), press menu, select copy, select 'internal memory to sd card', 'select frame' or 'all frames'. It should say 'copy ok?' Press OK.
Jul 10, 2010 | Fuji FinePix S8100fd Digital Camera
My screen shows lines and when I take a picture
Please reset the Camera and check if that helps.
To reset the Camera, just press the RESET button using a sharp-pointed object. The Reset button is located inside the jack cover. Please make sure that the Camera is turned ON while pressing the RESET button.
If the issue still persists, power reset the Camera and check if that helps.
To power reset the Camera, please remove the Battery Pack from the Camera and then press the POWER button for 15 seconds.
Then, reinsert the Battery Pack after 1 minute, then turn ON and check if that helps.
Thank You!
Apr 09, 2010 | Sony Cyber-Shot DSC-P32 Digital Camera
Reinsert memory stick
Are the contacts on the card clean? Is the slide switch on unlocked?
Sep 13, 2009 | Nikon Coolpix 990 Digital Camera
Pictures stored on card, and unable to retreive them on camera
Have you tried accessing the pictures via a card reader connected to your PC. It is possible the card is damaged and you will not be able to recover your pics. But it is worth a try. If you do not have a card reader take the card to a camera shop and see if they can see and manipulate the pics to another card, then reformat the card and reinsert it to see if it then reads anmd writes.
Jul 22, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
It is charged but I can't figure out what to do next. Instructions were thrown out. It doesn't turn on for more than a second.
plug into usb. Let charge for 2 hours.
Press power button for two seconds to turn on/off
Press button that looks like clock face to cycle between 1 5 15 minutes (small lcd will show)
Then pre power button once.
Green light shows is on, LCD shows how
many pictures taken.
Once you have taken pictures you have 15 hours to plug it into a pc and download them,
shows up like a memory stick. After 15 hours it loses memory and pictures.
If device is non-funtional, press recessed reset button in back. Then charge as above
- Ron S
Jul 12, 2009 | Uncle Milton Pet Eye View Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Problem with A610 Fuji - pictures wont dowload
Are you sure the computer s 'seeing 'the camera this time. USB can be a bit iffy. Leave the camera plugged in but switched off. Repbbit the computer and switch on camera Check 'My computer' to see in there is a 'New drive' indicated.
Aug 04, 2007 | Fuji FinePix 6800 Zoom Digital Camera
Tom tom one v2
Try resetting the device: -Charge it until it is full. -remove the SD card -press the reset button (with a pen) for 15 seconds -Hold the on/off button for at least 15 seconds -reinsert the SD card
Aug 04, 2007 | Tomtom One Europe v2 GPS Receiver
Pics not recognized by computer
I had the same problem. Is there a Memory card in? If there is one it probably is corupted. Happend to me. If it isn't try taking it out and puting it in the port on your machine.
Jun 05, 2007 | Kodak EasyShare Z650 Digital Camera
ViewSonic VFD1028W-11 - digital photo frame Logo
Top ViewSonic Photography Experts
pontelemon
pontelemon
TC CAMERA REPAIR.Com...
Are you a ViewSonic Photography Expert? Answer questions, earn points and help others
