Question about Water Filters & Coolers
Continental water cooler ce29109
User guide
Lost my cord and book
The manual is here.
You can get a cord from any electrical component shop. Look in your local Yell Pages as they are all a standard type.
Continental CP43729 Instruction Manuals and User Guides
Sep 21, 2015 | Continental Electric CP43729 - Continental...
Mastercool Adobe P550A portable water cooler. Where can I get a user manual?
try searching on line for a water dispenser manual rather than a water cooler manual
Jun 11, 2015 | Mastercool Heating & Cooling
Temperature on a whirlpool D10 watercooler
Lisa coolers similar to yours=> Whirlpool Dual-Temp Top-Loading Water Cooler
It appears that customers gave a not so good review yet being inexpensive this is common when most products are imported from China. The WHKM-D10 that you have now is now called the WHKM-10DP Whirlpool Dual-Temp Top-Loading Water Cooler with Heated Water. Wish I had better news, but please keep me in mind for any other Whirlpool, Maytag, Kitchenaid, Jenn-Air, Amana,or GE Home Appliances, Thanks, John Tripp/AKA Sea Breeze
http://appliance911seabreeze.com/
Whirlpool Factory Technician
You also can find a user manual by clicking here=> Whirlpool Product Literature; Manuals, Guides and Instructions
Nov 15, 2011 | Refrigerators
Is it possible to program my 99 lincoln continental to run at a cooler temperature?i just want it to get barely hot enuff to blow warm air
Depends on where you are ... You can not make it run cooler ... what you might do is remove the thermostat which will let the water circulate all the time which might be a little cooler. BUT - If you do this, you will toss out the profile your car uses to run at its best economical and polution free settings. It will cost you more to operate and it will not run as good.
Please dont do it ...
Thanks for your visit today.
Jan 12, 2011 | Vehicle Parts & Accessories
I have a 97 Lincoln Continental. I am trying to replace the cooling fan. I have the shroud loose but can't figure out how to get out. Any help would helpful. Thanks
YOU NEED TO TAKE IT OUT FROM THE BOTTOM REMOVE PLASTIC SHROUD THEN DRIAN AND PULL LOWER RADIATOR HOSE FROM RADIATOR AND THE REST IS PRETTY SELF EXPLANATORY MAKE SURE YOU BUY THE CLIPS FOR THE WIRRING BEFORE YOU EVEN START
May 09, 2009 | 1997 Lincoln Continental
I need 2 know how to remove the radiator
THIS IS a 1995 LINCOLN CONTINENTAL W/4.6L ENGINE
iIBELIEVE TOWN CAR IS DIFFERENT LET ME KNOW IF SO AND PLEASE DONT FORGET TO RATE ME
REMOVAL
  1. Disconnect battery ground cable (14301).
  2. Drain engine coolant.
  3. Remove engine air cleaner (ACL) (9600).
  4. Remove upper radiator hose (8260) from water bypass tube.
  5. Remove radiator overflow hose (8075) from radiator (8005) and fan shroud (8146). NOTE: Loosen transmission oil cooler lines while securely holding radiator connector with a back-up wrench.
  6. Remove transmission oil cooler line from oil cooler inlet fitting.
  7. Remove nuts retaining A/C condenser core to the radiator.
  8. Disconnect engine control sensor wiring (12A581) from the auxiliary electric cooling fan motors and the CCRM.
  9. Raise vehicle on hoist.
  10. Remove splash shield from lower radiator support (16138) and front sub-frame (5C 145).
  11. Remove lower radiator hose (8286) from radiator. NOTE: Loosen transmission oil cooler lines while securely holding radiator connector with a back-up wrench.
  12. Remove oil transmission cooler line from oil cooler outlet fitting on radiator.
  13. Remove retaining screws for power steering/transaxle oil cooler and position cooler aside.
  14. Support fan shroud, radiator and A/C condenser core (19712) with a suitable jackstand. Remove lower radiator support. Position jackstand aside and carefully remove radiator and fan shroud.
  1. Remove two retaining bolts for fan shroud at top of radiator and remove fan shroud from radiator.
  2. Remove upper radiator hose from radiator.
INSTALLATION
  1. Follow removal procedure in reverse order.
  2. Tighten fan shroud bolts and A/C condenser core nuts to radiator to 3-5 Nm (27-44 inch lbs.) .
  3. Tighten lower radiator support bolts to 8-11 Nm (71-97 inch lbs.) .
  4. Tighten transmission oil cooler lines to fittings to 25-28 Nm (18-21 inch lbs.) .
  5. Tighten power steering/transaxle oil cooler and splash shield retaining screws securely.
  6. Refill engine coolant.
Feb 11, 2009 | 1995 Lincoln Continental
Water Filters & Coolers Logo
73 people viewed this question
Top Water Filters & Coolers Experts
John Tripp
John Tripp
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
