Question about MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Right headlight not working - MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker
Left side of my headlight is not working . I believe it was affected by the start whick was fixed not long ago. Is it true ? If it is true how can I solved the issue? My car is Honda CRV 2007
What do you mean by saying the left side of your (singular) headlight is not working? Is the right side of that SAME headlight working? Do your headlights have dual or twin filaments in each one? Or do you mean that the left entire headlight is not working, but the right side headlight is working okay? Please clarify your opening statement.
May 16, 2017 | Honda Cars & Trucks
I have a 1994 geo metro. The headlights went out. I checked the fuses. They were ok. The ground wire in the under dash fuse box looked discolored. I made a ground and the left side head light came on...
On these cars the headlights get power from a right and left fuse and the headlight / dimmer switches provide the ground circuit. Both headlights are connected to one ground wire for high and one for low beam. So if one works and the other does not, the problem should be in the wiring before the headlight switch. Red is for high beam and red-white is for low beam. You should be able to jumper the red-white wire on the right headlight and make the low beam circuit for both sides work to test it.
Jan 22, 2014 | Geo Cars & Trucks
Check the bulb socket to make sure it's making good contact. Even add some dielectric grease to possibly help. Most sockets will melt and not be able to see it till you remove the bulb.
Oct 22, 2013 | Chevrolet Colorado Cars & Trucks
Headlight dim
Remove headlight and check electrical connection socket for corrosion on connecting pins.
Oct 02, 2013 | Subaru Cars & Trucks
2002 ford focus headlights inop
All types of car headlight problem troubleshooting.Click the link below :---All headlights not working? http://repairhelpcenter.blogspot.com/2012/01/all-headlights-not-working.html
---------This will help.Thanks.
Feb 12, 2012 | 2002 Ford Focus
Headlight relay location
check all the light first .tell me the problem you have , and Did the problem come on suddenly or was some previous action or work done...and tell me the headlight (low) and (high) working (OK) .signal light working or not what you mean right side headlight . what is not working .
Dec 02, 2011 | 2000 Volkswagen Beetle
Turn signal doesn't work when headlights on
It sound like you have a grounding problem, does the headlight on the left seem dimmer than the right? Check the ground wires and the light sockets for corrosion.
Mar 27, 2010 | 2003 Chevrolet Venture Passanger
Right headlight not working properly left headlight not working
You have a short in your electrical system or bad ECM.
Jul 05, 2009 | 2000 Pontiac Firebird
MTX Dodge Ram Quad Cab 2002-2003 Thunderform, Loaded with Dual 10 Inch Subs and Amplified, Charcoal Car Speaker Logo
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
