Question about Philips 19PFL3403D/27 19 in. LCD TV
NEED TO RESET 19PFL3403D/27 - Philips 19PFL3403D/27 19 in. LCD TV
Where can I buy a power button
you can buy it from any eletronic spare part selling shops.
Oct 27, 2013 | Philips 19PFL3403D/27 19 in. LCD TV
Tv will not turn on
If the LED lights up and turns green or stays red then you have a power supply problem
Dec 08, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Where can I obtain Power Supply for Phillips 19PFL3403D, since my unit has no power or standby light...???????
Check the power source?Yes,than tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Oct 20, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Volume goes up to 100 or up to 0 , what is the problem? also I can't turn the tv off
it seems the volume button on the remote has jammed inside the housing.try using only the front panel to control the volume. or you need to explain well once again then we can help
Jun 25, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
19pfl3403d/f7 rolls constently thru the channels
If it does this, even when the remote control is in a different room (or has the batteries removed), you need to have the set serviced by a professional.
If it only happens when the remote is nearby then you may actually have stuck keys or the equivalent shorting inside the remote. Some remote cases open easily and you can blow out the inside and under the keys with "canned air" spray.
If the problem is with the remote, you can buy a cheap replacement at a local drug store. They will be labeled "universal" remote. However, no remote is truly universal. Check the label on the package and verify online that the device will work with your brand of TV BEFORE you buy.
Never open the case of a CRT or Plama television as there are LETHAL voltages inside for WEEKS after the set is unplugged.
Jan 02, 2010 | Philips 19PFL3403D/27 19 in. LCD TV
Model 19PFL3403D/27 having trouble powering on the TV. Even after pressing the POWER button the the side of the TV and toggling from OFF to either STANDBY or ON. It should not be this difficult just to...
The most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 27, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
How to scan for new digital channels small Philips flat screen
From the menu you should see set up the cannel scan should be there.. If all else fails unplug the TV for a few minutes then plug it back in. It should ask if you want to set up the tv, Say yes and follow the steps.
Jun 16, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Local TV channels drop out after a few minutes
We're still hanging on by our toenails waiting for a helpful response from FixYa. We did contact Philips tech support and they basically said that we need a new TV...so they're sending one to replace this one, and we are sending back the "old" one (that we just bought in December '08).
Apr 09, 2009 | Philips 19PFL3403D/27 19 in. LCD TV
Philips 19PFL3403D/27 19 in. LCD TV Logo
55 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
