I've had success in the past by using a thin knife blade, or metal ruler (a medium sized pocket knife works well)... Stick a small square of double-sided tape on the blade/ruler... IMPORTANT! Very gently slide the blade/ruler into the slot, do so at a slight angle so you first clear the edge of the disk. Then gently, but firmly, press the blade/ruler down on the disk so the double sided tape sticks... now press the 'eject' button on the keyboard (or the go to Finder and select the disk and click the eject icon), at the same time try to gently wiggle the blade/ruler outward to assist in removing the disk!
First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu.
If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X.
Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared.
If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar.
Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder
Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button.
Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism.
Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray.
Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. )
If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
This is about trying to eject a CD or DVD stuck in a slot drive. Most computers have a drawer-based cd drive which rarely suffers from disk jams.
Some high end PCs (and nearly all Macs) have slot drives where you feed the disk into a slot, the disk is then pulled into the machine. This gives better structural strength to the case, looks neater etc etc...
The problem is that occasionally a disk will get stuck. and there’s no little release hole on the front to push a paperclip in. There is lots of advice on the internet for the Macs, the Wii, and Pioneer drives of varying types, and most of these advise OS tricks, or firmware commands, however this trick is for when all those methods have been tried, and the disk is still trapped in the machine.
The idea is to stop the disk spinning and fool the drive into thinking the CD is bad, and it will eject it. I was taught this trick by a retired engineer, and it works a treat.
Fold a piece of cardboard (I used the side of a Frosties box) lengthways twice, until it’s quite stiff... Carefully push it into the slot until it bumps up against the edge of the CD/DVD.
Start the machine, and push the cardboard firmly against the disk to prevent it spinning. Wait for the regurgitating noises, and remove the cardboard to allow the disk to be ejected.
Have you tried holding the mouse or trackpad button down immediately after powering on. This forces the CD drive to eject during boot up. See this page for all sorts of useful Mac tips.
You don't say which version of the Mac OS you're using, so I'll assume OS-X. Control-click the iTunes icon in the Dock, choose Force Quit, and then try ejecting the CD from the Finder or Disk Utility.
Or
Reboot and hold down the trackpad bar mouse button
To eject a CD from a Macintosh, start from power-off. Press the power button, and immediately hold down the trackpad button. Continue to hold the button until you hear the optical drive eject, or try to eject. If the CD does not eject successfully, then it is physically stuck, which is a different issue and requires professional service, which may involve replacement of the optical drive.
CD Stuck in Device First try the normal methods to remove the disc. Drag its icon to the Trash can in the Dock or select 'Eject' from the File menu. If you are running a virtual machine, e.g. VMFusion, ensure that the CD is disconnected from the virtual machine. This will sometimes allow the CD to now show up in Mac OS X. Shut down the computer and start up whilst holding down the mouse button. This may take some time, but keep your finger on the mouse button right up until the disc comes out or the log-in screen has appeared. If you have Toast Titanium installed on your computer, choose EJECT DISC from the menubar. Sometimes you can successfully use the eject disc button in iTunes even if the disc is not visible to the Finder Open Disk Utility and choose the disc you wish to eject in the left-hand pane, then click on the Eject button. Some Macintoshes have a paperclip hole that you can insert a straightened paperclip into, manually triggering the eject mechanism. Open Terminal and type "drutil tray eject" to eject the disc/tray, and "drutil tray close" to close the tray. Restart the computer while holding down Command-Option-O-F, to enter the Open Firmware prompt. Type "eject cd" without the quotes, and press return. The disk ought to eject. To start into OS X, type "mac-boot" without the quotes. Press return, and the computer will continue with the startup. (This will not work on an Intel Mac. There is no Open Firmware on Intel Macs. ) If your computer has an eject button on the keyboard, restart the computer holding down the Option key. When the startup disk selection screen appears, let go of the option key and press the keyboard's eject button.
A CD or DVD disc can become stuck in your Macintosh. It may not be appearing on your desktop or could be causing the computer to lock up if the computer cannot recognize it properly.
[edit]
Solutions
Hi
You can try tipping the Mac on its side with the DVD drive pointing down and shake it gently while pressing the Eject button on the Keyboard.
If that doesn't work, the only other way is disassembly :(
YouTube Vids:
iMac Disassembly Part 1 iMac Disassembly Guide Part 2
