Question about Nuvico AL-1610 16 Channel Apex Lite Series DVR W/ 1TB
HDD BUSY DVR display says HDD busy
When there is an operator message like "this number is not in service", NBX phone turns to extension and Audio codes turn to busy tone.
Are you saying that the phone boots up and has the extension on the display but when called by another phone it is busy?
Apr 02, 2014 | 3Com NBX 2101 IP Phone
I have a Lorex edge LH314 320GB, DVR beeps and displays HDD is not formated.
You need to format the hard drive using the built in formatting utlity. Did you replace the hard drive in the DVR maybe?
Nov 15, 2012 | Lorex EDGE L314501C4 4-Channel Network...
Will not leave busy....
If you are getting a 146 error, the HDD is failing. Back up your data, as you can then replace the HDD. No amount of tools or SW is going to change the fact that the drive is dying
Sep 29, 2009 | Dell XPS M1530 Laptop
View finder displays "busy" and the shutter is half open
I can help you fix the BUSY Error or Error 99 of your Canon EOS Digital Rebel XS.
Installation of this Canon EOS Digital Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
May 28, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Norstar Flash
phone is not programmed for forward busy no answer.
Feb 06, 2009 | Nortel Norstar 16-Line PBX Speakerphone
MY PHONE SAYS "MAKE BUSY" ON MY LINE. IT WILL NOT FWD TO VM/ ONLY BUSY!!
I was given a set of codes to use to reset the "make busy" sign, which was **1, not sure if these codes pertain to all phones, and to turn off "head set" i was told to use **3. I was then able to see the date and time again!! I also was able to pick up my phone when it rings instead of having to press a certain ext to answer from.
Nov 03, 2008 | Mitel Superset 4025 Corded Phone...
Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Sep 10, 2008 | Toshiba e-Studio DP170F Plain Paper Laser...
Getting "busy" display on all modes except no-flash mode...
The "Busy" code will be on when the camera trys to use a flash and waiting for its charging action. Upon completion of charging the mechanism returns a signal to the camera to fire the shutter.
That means now your camera has something wrong on the flash unit and the camera waits for some certain time frame to finally determine it cannot complete a photo-taking command.
An "ERR 99" denotes that this kind of error has not been encorded explicitly and needs investigation services.
Dec 17, 2007 | Canon Digital Rebel / EOS-300D Digital...
HDD LED
You are correct, the HDD LED is simply for informational purposes and does not need to be connected. I took a look at the manual for you card (the pictures are pretty bad). It states:
"JP2 - HDD Busy LED Connector"
So are the pin headers labeled? They may have faint white printing near them (or on the back of the card). The one labeled JP2 should be the LED pins.
Sep 14, 2007 | Sabrent SBT-RDIT PCI IDE Silicon Image...
Nuvico AL-1610 16 Channel Apex Lite Series DVR W/ 1TB Logo
57 people viewed this question
Top Nuvico Home Security Experts
Lawrence Oravetz
Are you a Nuvico Home Security Expert? Answer questions, earn points and help others
