Question about Clarion Car Audio & Video
Clarion DRB3675 wiring connections
Which wire is connected to what
SOURCE: clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Posted on Apr 15, 2008
starlet4life
  • 89 Answers
Usually the yellow is for ignition switched-red is permanent +...;)
Posted on Sep 27, 2008
DrWho_64
  • 35 Answers
SOURCE: clarion DRB3675 cd and radio with clock
to set the clock just press and hold the DISP for 5 to 10 seconds, button while the clock is is displayed. When the the time starts flashing, use the DISP button to adjust the time. When you have the correct time, just hold the button until the clock stops flashing and you're done.
Posted on Jul 09, 2009
  • 20 Answers
i have the same stero in my boat made 2004 it is easy red(hot) black (Ground) Orange (Illumination) (hot) the 2 fused yellow is bat direct (memory) blue w/white stripe (remote) solid blue (power attenna) the 2 white wires ft left speaker, 2 gray rt front, green left rear, purple rt rear, the single brown is for the changer i believe
Posted on Aug 11, 2009
  • 22 Answers
SOURCE: I need to know the wiring diagram for a Clarion
RED 12 VOLTS SWITCHED
YELLOW UNSWITCHED 12 VOLTS
BLACK GROUND
BLUE REMOTE OUT
WHITE,GRAY,GREEN AND VIOLET PAIRS : SPEAKERS
Posted on Sep 20, 2009
Testimonial: "Great information. A very quick response with the correct information. Thank You"
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
CAN ANYONE HELP IM TRYING TO WIRE UP A CLARION AB213R RADIO CASSETTE BUT I DONT KNOW WHICH WIRE IS WHICH. I HAVE A BLACK CONNECTION WITH FOUR WIRES. RED..WHITE..ORANGE..PURPLE..ALSO A WHITE CONNECTION WITH...
if you go on google enter clarion ab213r wiring diagram
and it should tell you what every wire is.
also enter your vehicles info and look up the wiring diagram for that also
it should be easy from there
Mar 17, 2010 | Car Audio & Video
How do i bypass emergency brake wire on my clarion to play movies
connect the wire to a ground/negative point, please note this is a saftey feature.
Nov 15, 2009 | Clarion Car Audio & Video
I just install new Clarion BTL370 in the Clarion
A few things to check...
Make sure the receiver is set to "tel sw" or something similar in the menu. From there, you should be able to set the call to the left or right speaker. Make sure you set the headset to the same side.
Another thing to check, make a call and get connected through the headset. Now wait a few seconds and push a button on the phone to power the backlight. If it is wired correctly, you should see the "connected" timer on your phone keep time. If it appears that you are connected, the problem is most likely in the settings.
Also, if nothing else works, make sure that you have the accessory wire(should be red on the BLT370) connected to the right wires. All the other wires will power it on even if this wire is not connected correctly.
Jul 17, 2009 | Clarion MAX675VD Car DVD Player
Memory problem
you have connected the power wires wrong make sure the yellow wire is connected to 12v battery continuous and the red is connected to accessories
hope this helps pls rate ppl havent been rating thanks
Apr 10, 2009 | Clarion DXZ428R CD Player
I need a plug for the back of a clarion drb3675 16 pin plug
you might be able to call clarion themselves and see if you can order one through them, if not take a look on ebay they sell harness all the time for this radio.
Feb 22, 2009 | Clarion Car Audio & Video
Clarion DRB3675 cd and radio with clock
Aug 05, 2008 | Clarion DXZ665MP CD Player
How to install the wires for a Clarion DXZ375MP
there shold be a "hot at all times" wire in the dash where the old deck came out of, that is what you want to wire them too.
Nov 28, 2007 | Clarion DXZ375MP CD Player
Car Audio & Video Logo
21 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
