Question about Samsung SCX 4521F All-In-One Laser Printer
The Samsung scx 4521 printer JAM
The Samsung scx 4521 printer keeps getting paper jams every 20 prints it jams, is this a mechanical problem. is there a solution or is the trash the best solution?
    Sergeant:
  • 361 Answers
Ithink it is a hard were pr oblem we should clean our printer time by time, there is many dust inside, they can make disattacment between sencer and parts ,so we get this information. open printer and also if u open drom and other part open , then blow air by air blower machin e.we solve more than 80% thise type case in our lab .
Posted on Jun 19, 2009
My samsung scx-4623f always "paper jam in exit area" every time i print even though i always put out the jammed paper in the exit area.
While Samsung SCX-4623f printer always "paper jam in exit area" you get paper checks or trigger sensor paper cup
cong ty bao ve support
good luck
Jul 07, 2014 | Samsung SCX4623F Laser All-in-One Printer
Samsung SCX-4521 "Paper Jam 2" won't clear
Hi there have you tried the door at the back of the machine as there maybe a piece stuck in the fuser unit. If not open the back door and check that there is a small black lever in the middle of the two rollers sticking up as this is the sensor arm that determines that there is a paper jam or not. If this is still there then the paper will be stuck just after the paper cassette within the paper path.
Hope this helps you.
Goodluck,
please don't forget to rate me as fixya..
Feb 01, 2008 | Samsung SCX 4521F All-In-One Laser Printer
My samsung printer scx-4521 not print this message is paper jam 01
Dear
Pl. check the SMPS found under back cover, at the bottom of the smps ther is a sensor and leaver attached on base. Do check the spring and its position, replace the smps or sensor.
Thanks.
Jul 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX-4300 paper jam
sir i have samsung scx 3201 printer but paper loading problem so plz solloved my problem
Oct 23, 2012 | Samsung SCX-4300 All-In-One Laser Printer
My Samsung scx 4x20 printer shows paper jam in the dsisplay but there is NO paper jam. Can not get the error away and the printer refuses to print. What to do?
I suppose that the exit paper sensor in fusing section is broken (ussually when you pull out paper jam you can brake this little black or blue pawl). You can order and buy only this paper sensor pawl (very cheep).
pifonski
Feb 23, 2011 | Samsung SCX 4200 All-In-One Laser Printer
My printer scanar photo copy machin (model 4521 f) problem papar jam
turn off your printer wait few second then turn on your printer theleft paper come ot automatically
www.anishatechnology.com
Apr 10, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Machine says there is a paper jam when there is no jam. Shows jam in exit but the paper never even starts to get picked up from the main paper cassette but it will feed fine frome the mp tray. any...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 08, 2009 | Samsung SCX-6320F All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
PRINTER DID NOT TAKING PAPER AFTER PRINT OPTION AND PRINTER STOPS AFTER 2INCHES PAPER
hi
I guess its a coz of paper jam in your printer.
Heavy cardstock and certain types of slick or coated paper can cause frequent paper jams. To better isolate the cause of your problem (machine or paper), try a new **** of regular 20 lb copy or laser paper.
  • Don't Overload
    Overloading your paper tray can cause paper jams. Your manual may say that your input tray can hold 250 sheets -- but if you keep getting jams, try loading 225 sheets instead.
  • Check the Paper
    Check the minimum/maximum paper weights that your printer can handle. Paper that is too thick, or too thin, can cause jams.
  • If you still get paper jams after this may be its time to clear the internal of the machine..You might want to have a look at the following link..
  • http://lasertoners.blogspot.com/2005/10/laser-printer-jam-fix.html
hope u will b helpffull
thankyou.
May 08, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I had this problem too. For me the answer turned out to be the paper sensor in the back part of the machine, behind the little back door just under the top part of the machine. This sensor hangs down from a thin rod that runs across the width of the machine, and is held in place by a small spring that encircles the same rod that supports the finger. The finger had apparently gotten moved so the spring was dislodged from its proper place. I was able to rotate it around the rod with my finger & get the spring moved back to where it should be. This seems to have cleared the problem--I'm keeping my fingers crossed.
Jan 22, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F All-In-One Laser Printer Logo
332 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
