Question about Harman Kardon AVR 35 Receiver
Avr 35 not working
Front speakers
AVR 3700 no sound
do headphones work with or without speakers attached? does unit light up? Check fuses. If breaker pops, or replacement fuse blows, it needs repair.
Nov 27, 2013 | Harman Kardon AVR 500 Receiver
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
Denon AVR-1706 Left Front and Rear speakers stopped working. Any suggestions?
go into the settings menu and do a sound test using the recievers pink noise tester to test each speaker connected, if while doing this test you still get no sound from those two speakers check connections, make sure speakers are not blown.
if speakers and connections are good then the reciever needs repair
Jul 18, 2009 | Denon AVR-1706 Receiver
My Harman Kardon AVR 254 is not responding. None
I am having the same problems with my AVR 254, did you find a solution?
Thanks
Mar 15, 2009 | Harman Kardon AVR 325 Receiver
Denon AVR-1507 No sound on left front channel
Because the sound is only faint says to me that the power amp that controls the left channel is faulty. You need to look at the device(s) on the heatsink and probably replace them.
Dec 28, 2017 | Denon AVR-1507 Receiver
Denon AVR 900
you need to put the volume up on those speakers you can only do that with the romete s you kinda stuffed unless you get the remote.
Aug 13, 2007 | Denon AVR-900 Receiver
Harman Kardon AVR 35 Receiver Logo
64 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
