Question about Sanyo Televison & Video
Tv turns off itself - Sanyo Televison & Video
Suddenly turned off. Why won't it turn on again?
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears to turn itself off. These cases are listed in the following table by category.
HELP! My LG LCD TV suddenly turn off by itself and ... - AVS Forum ...
www.avsforum.com/.../1084538-help-my-lg-lcd-tv-suddenly-turn-off-its...
Nov 13, 2008 - 30 posts - ‎22 authors
This morning, I turned it on, its suddenly turn off and on by itself repeatly. I can't even control the tv using the remote again. Then I try the trick ... Samsung TV turns on and off repeatedly before staying ...
Jul 1, 2014
My HDTV Shuts itself OFF then it Turns On by itself ...
Sep 12, 2008
More results from www.avsforum.com
Samsung Smart TV turning off - Forums - CNET
Dec 29, 2015 | Televison & Video
Hisense tv troubleshooting
Check the tv menu settings...go to where you set the date and time etc... usually in the general section..
Look for timer or timers...turn off sleep timer, turn off power on timer and turn off power off timer...cheers
Feb 06, 2018 | Televison & Video
TV turns off and immediately on again, by itself.
sounds like a defective str power regulator ic .......but my advice get a tech to resolder all the pins at the power suppy board area, there may be some open pins that triggers the on and off episodes
Jul 18, 2013 | Televison & Video
Plasma TV turns off by itself-won't sty on for
when i turn my 32 inch VIVIO plasma tv on it turns pff by itself. i want to know why this is happening
Dec 07, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Turns off by itself after i've turned it on
I have this same TV and had a similar problem. This may or may not be the same case with yours. The button panel on the front of your TV may be having connection problems. Mine would come on and off by itself. I took the front panel off and cleaned the connection on the button board with a q-tip and a little dab of alcohol. This cleared up the problem of it turning itself on and off.
Mar 20, 2009 | RCA P46924 46" Rear Projection Television
Turns off by itself!!!
The flyback transformer are damaged .
May 26, 2008 | RCA TruFlat 27F520T 27" TV
My TV turns itself off and on by itself.
You have a timer that has been accidently set by someone by the remote control.
If you have an instruction amnual for the tv, it will tell you how to turn off the tv's timer.
Feb 13, 2008 | RCA P52930BL 52" Rear Projection...
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Televison & Video Logo
12 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
