Question about Teac PD-H503 3-Disc CD Changer
My Frigidaire Electrolux oven,model #CGEB27S7CS1 and serial #NF71222373 has lost all digital displays and also all functions.Was still heating fine but could not shut it off.Had to shut off main power supply.Does not appear to have any fuses on this unit.What could be the probem.
Frigidaire microwave professional series
If its the magnatron I suggest a technician
Apr 18, 2014 | Microwave Ovens
Thermostat broken
Good Morning a_t_pearson, this is Z. Thank you for your post! I understand that the thermostat is broken on your top Frigidaire oven; therefore I'm assuming that you have a double-wall oven. If so, please help me understand what you are referring to by thermostat? Is your oven not preheating or reaching desire temperature? Are you speaking about the bake and/or broil elements not heating? May I please have your model number? The serial tag, which lists your model number, is typically located on the front of the oven, on the left side, as you open the door. With this information I can better address the issue at hand. Thank you!
Apr 01, 2014 | Electrolux Ovens
I have a Whirlpool electric acubake wall mounted double oven which is 15 yrs old. Most of the time the digital controls work fine. Twice now the digital display has gone totally dark. An hour or so...
Anonymous, we're sorry to learn that your Oven isn't heating. We will be glad to further review your concerns. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, contact number, address, model and serial number.
Oct 23, 2017 | Whirlpool Ovens
Is there a recall on this oven plef398aca that I
Here's the Deal everyone . . . I found this site while researching a used version of this Frigidaire stove (and similiar models, like Kenmore Pro/Elite, etc. all made by the same parent company- Electrolux). The stove I'm looking at also has had the F7 code and will not heat burners while displaying this code. In following up w/ the parent co., I learned that many of these "similiar" models are in fact on recall, and Electrolux is fixing them all at NO Cost to the owner, even if you are NOT the original owner you are covered under the recall terms. I suggest everyone call Electrolux in Georgia and see if you model is on the list!! Good Luck, don't mess with it, just call and get on it.
Apr 16, 2010 | Frigidaire PLEF398AC Electric Kitchen...
Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Oven - lights are on but no heat from oven or burners
You must check your incoming power for 220 volts. You have lost one leg of your power. Either a bad breaker or bad wall outlet or bad range cord.
Jun 26, 2009 | Frigidaire Ovens
F3 message displayed
HI, you oven temp sensor if malfunctioning. the circuit is open. its basically dead. Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
May 22, 2009 | Frigidaire 24" Built-in Single Electric...
Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
Hello stevefer
Welcome.
You said, Your Electrolux built in wall oven, lights and digital display work fine, fan works fine, but the oven will not heat regardless of the mode (broil, bake, convention roast, convection bake)
First,
1.What is the Model Number and the year of your wall oven?
2.Did the oven light up and display with any error codes?
3. Did you try to turn the breaker off for 5 minutes to see if this will reset the system?
Perhaps the heating element is failing and may need to be replaced.
I will be able to better assist you when you reply with this information.
Waiting your response.
Huuum
Oct 16, 2008 | Kitchen Ranges
Teac PD-H503 3-Disc CD Changer Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
