Question about LG DLE1001W DLE1001W 27" Top Load Electric Dryer With 7.3 Cu. Ft. Ultra Large Capacity Distinct And Modern Front Control Design 9 Cycles Smart Diagnosis HydroshieDual LED Display In White
Power Cord Do I need a 3 or 4 wire power cord?
4 Suggested Answers
SearsTechToo
  • 261 Answers
SOURCE: electric dryer cord switch from 3 to four prongs when the wires aren't colored?
I wouldn't worry about that, make sure you can fully see the terminal block where the wires install. Left to right usually is black, white and red. Make sure green is on ground at the case and if there is a white wire there already, just add the green to it. The cord also on a 4 wire is coded so just line up the colors.
Posted on Sep 19, 2008
  • 21 Answers
SOURCE: power cord
Download the user manual. http://www.retrevo.com/support/LG-DLE5977-Dryers-manual/id/438ag222/t/2/
Posted on Feb 12, 2009
omaharox
  • 165 Answers
SOURCE: LG DLE2514W Power does not stay on. Power cuts
If you move the cord @ the outlet and the dryer shuts off replace outlet if the prongs on the cord are not damaged.
If you wiggle at the dryer side and it shuts off un plug the dryer remove acess cover and inspect end of cord. Ck. and make sure terminal nuts are tight. and not burnt due to a loose connection.
Posted on Jan 20, 2010
I need replacement power cord
Well, if the power cord isn't hard wired to the TV, then the two most likely options are either a figure 8 cord or an IEC cord.
Here's a figure 8 at monoprice
3ft 18AWG Figure 8 Shape AC Power Cord Cable Polarized 7 1 15P Black...
Here's the IEC cord at monoprice 10ft 16AWG Power Cord Cable 3 Conductor PC Power Connector Socket C13 5...
Sep 05, 2014 | Coby LEDTV2326 23 TV
The power wire hook up for the trc-481 cb radio
  • Hi, I can help.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sep 18, 2011 | Radio Shack Radio Communications
Customer has lost his power supply cord. where can he purchase another cord. power cord is three prongs.
  • Hi, I can help.
  • For the Radio Shack TRC-447 this is just a standard 3 PIN DC cord. Many CB's use the same cord and they are interchangeable. Some Cobra, Uniden, Radio Shack use the same cord. Texxcomm is a great place to get parts from.
  • If you have any coimmments please feel free to leave them here.
Regards, Tony
Sep 07, 2011 | Radio Shack TRC-447 CB Radio
Trying to make a 3 prong power cord a 4 prong power cord need to look at manual for it says to see manual and i do not have one
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 14, 2010 | Dryers
New house has three prong recpticle dryer cord has four prongs. Can I use a three prong cord and strap a wire to the fourth wire on back of dryer? If not got a solution?
If the new house has an existing three-wire outlet, the simplest solution is to install a 3-prong power cord on your dryer. The following link explains the differences between a 3-wire and 4-wire configuraiton:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
So...if you need to install a 3 prong power cord, it should be wired as follows:
RED (HOT) 120VAC to RED
BLACK (HOT) 120VAC to BLACK
WHITE (NEUTRAL) 0 VAC to WHITE - a Ground wire needs to be connected to the Neutral lead at the terminal block and grounded to the dryer cabinet.
The other alternative would require you to install a 4-wire receptacle so you could still use your current power cord. A certified electrician is recommended for this job and may cost you some money. A replacement power cord, on the other hand, usually costs less than $20 and can be found ay any hardware store.
If you have any questions, please post back and let me know. I hope you find this information helpful.
Jun 10, 2010 | Dryers
Need to replace power cord on Whirlpool RF367BXP what color wire is the neutral wire and what colors are the hot wires for a 3 prong cord
Here is a picture on how to wire the range.
The black and red are the hot wires and the white is the neutral wire. the green is the ground you will not have the green with a 3 wire power cord.
May 31, 2010 | Whirlpool RF367 Electric Kitchen Range
We were recently given a kenmore dryer, without a power cord. How do I attach the 3 wire power cord that I bought to relace it?
Attach the power cord as follows:
1. Remove the cover on the terminal block on the back of the dryer.
2. Match the corresponding wire colors as follows:
a. RED - HOT (120VAC)
b. BLACK - HOT (120VAC)
c. WHITE - Neutral (0 VAC) - should have a ground strap attached, tying it equipment ground.
3. Make sure you use the power cord strain relief clamp when installing the power cord to prevent chaffing of the insulation and wire strain which can lead to broken wires.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
For clarification purposes, the following link explains dryer power cord configurations/installation in detail:
Mar 17, 2010 | Dryers
Changed from 3 prong to 4 prong power cord ,now theres no power.
Please review the following link:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Do you have your power cord wired correctly? Please read through the link thoroughly and confirm the wire color coding and the placement of where you have the wires terminated. I hope this helps you. Let me know if you have further questions.
Jan 04, 2009 | Estate EED4300SQ Dryer
LG DLE1001W DLE1001W 27" Top Load Electric Dryer With 7.3 Cu. Ft. Ultra Large Capacity Distinct And Modern Front Control Design 9 Cycles Smart Diagnosis HydroshieDual LED Display In White Logo
13 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
