Question about VeriFone (M19755014US1) Magnetic Card Reader
Ftp password password username ftp
Server erro 530 , error on page cause it to work incorrectly
Error Code 530 b> This error code means that FTP authentication was not successful. The combination of the username and password you've typed was incorrect, thus you were denied access to the FTP site. It could also mean a misconfiguration in IIS: You've allowed only anonymous access for FTP, but denied anonymous access for all IIS services. Verify that the username and password you used is correct or check if anonymous access is allowed by leaving the username and password options blank.
Jan 12, 2013 | Computers & Internet
I HAVE DWL-3200AP AT HOME WORKING IN INSECURE MODE.I WANT TO MAKE IT SECURE BY HAVING A KEY TO ACCESS INTERNET THROUGH IT.PLEASE TELL ME HOW CAN I DO IT.
open your internet browser and type http://192.168.0.50 to access you router's settings. if asked for a username and password and you have them use them. if you've never set them up type "admin" for the username (without quotes) and leave the password field blank. The serial number, hardware version/revision information, MAC address and model number, will be located on a label on both the outer box, and on the adapter itself, usually attached to the bottom of the unit. I got this info from your 113 page manual that has diagrams, instructions and explanations for the settings, and everything else. your manual is here ftp://ftp.dlink.com/Wireless/dwl3200AP/Manual/dwl3200AP_Manual_104.zip
hope this helps
Sep 16, 2010 | D-Link Computers & Internet
Trying to install d-link
try user: admin and password: admin.
Assuming you are installing fresh, if it doesnt take admin admin.
Try resetting the device. Follow instructions to reset the Dlink router
ftp://ftp.dlink.com/Gateway/wbr2310/Manual/wbr2310_manual_10.zip
A pin hole with Reset written over it, near to power socket.
After resettings any previous password will be reset to default
user: admin, password: nothing just hit enter
Hope this helps
May 20, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cant access dlink 514 router admin page!! help !!
I would reset the unit to factory setting and start again.
ftp://ftp.dlink.com/Gateway/di514_revB/Manual/DI-514_manual_07062005.zip
That will get you the manual so you see how to do an hard reset.
Feb 25, 2010 | D-Link DI 514 Wireless Router (DI-514)
Have many zip files, and do not know how to use them.
in hostname write the domain name that you have bought eg: www.example.com
in username write the user id that you gave whille buying the domain
password write the same password that you have for the above specified username/id
Jan 08, 2010 | Computers & Internet
Still cant solve it.
The default address to get to the web interface is 192.168.1.1
The default password is 1234 (No username required)
If that doesn't work, you can restore it to the factory default by pressing the reset button on the back and holding it in for 10 seconds. Be aware that doing this will erase all existing configuration information.
Here's a link to the quick start guide:
ftp://ftp.zyxel.com/P-320W/quick_start_guide/P-320W_1.pdf
Here's a link to the Users Guide:
ftp://ftp.zyxel.com/P-320W/user_guide/P-320W_1.pdf
Jun 27, 2009 | Zyxel Prestige 320W Wireless Firewall...
Uploading to the internet...
sounds like you just registered a domain name and purchased a web hosting package? if so your web host (godaddygo) should have supplied all that information (server name, username/pw, where to drop your files, etc.)
in general a host would give you a username/pw which you would use to a) sign in to some site to manage your account, b) sign into the ftp server, c) possibly use to sign into an email account that came with the package.
for ftp access to your web files it would typically be something like this
- if your domain was mywebsite.com the host name you use with your ftp software might be ftp.mywebsite.com (just an example - godaddy should give you that information)
once you login through ftp, yes you would typically see a folder called public_html - this is where you copy all your website files - once they are there then people access them by going to http://www.mywebsite.com (and any subfolder name you decide to create under the public_html folder)
you may also see a public_ftp folder - this is typically used to store files that you want to give access for downloading (software, movie files, etc.).
hope this helps - write back if you need more.
Apr 06, 2009 | Cosmi Perfect Website Creator (ROM03919)...
Ftp doing steps please
Do you really need to be using command-line? Here are the things you need to do this as simple as possible:
Information Needed:
Host address: (example: ftp.somesite.com)
username: (if not anonymous)
password: (if not anonymous)
Software Needed:
FTP CLIENT: download here
After you have it installed, follow the documentation in the help menu to connect to the server and transfer your file(s).
Oct 30, 2008 | Compaq Presario 700 470024-192 Notebook
I/purchased/software/professional/ftp/wsserial#/WSB-E000522040/my/e-maildianedidianolsn@aol.com/when i go to download link provided its/ok/at/first/than/asks/for/ftr/username/password/what/is/it
it should ask you for a username and password since your trying to access a secure server. if you had been provided with a username and password when you had bought the product then use it.
Mar 14, 2008 | Computers & Internet
VeriFone (M19755014US1) Magnetic Card Reader Logo
Top VeriFone Televison & Video Experts
Bosse Photos
Rozan Perry
Rozan Perry
Level 1 Expert
Are you a VeriFone Televison and Video Expert? Answer questions, earn points and help others
