Question about Maytag 24" Built-In Double Electric Wall Oven - Stainless-Steel
The digital clock and timer wont stay set and will keep going back to blinking
Should the two dots in the digital clock flash all the time?
yes...mostly. they are the "second hands" of the clock...sometimes, they indicate "cooking" or "timer"...but mostly they just blink to show the clock
Dec 19, 2014 | Fagor Ovens
Cant figure out how to get back to farenheit temp..
to change between fahrenheit and celsius
The temperature is preset at Fahrenheit, but can be changed to
Celsius.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound and “C” will appear on the display. Repeat to
change back to Fahrenheit. To remove, press UPPER OFF,
LOWER OFF or OFF/CANCEL. you can click on the link for guide http://www.ajmadison.com/ajmadison/itemdocs/8300609.pdf
Aug 16, 2008 | Whirlpool GBS277PDS Electric Single Oven
Forno sy36x oven.. following powercut, timer wont set, therefore oven wont come on. digits constantly flashing
after a power cut, the clock display will-automatically reset to 0:00 and begin to blink.
starting buttons left to rigth Press the
2nd and 3rd buttons simultaneously, release,
and then set the exact time (within 4 seconds) using
the +buttons.
advances the hours.
The button
- decreases the hours.
The time can also be changed in a second ways
1.Repeat all of the steps above.
2.Press the 4th
button, release, and then use the +and -
buttons to update the time.
Sep 23, 2014 | Ovens
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
MY 24 INCH BUILT IN SINGLE WALL OVEN DIGITAL TIMER
turn power off at main box the back on retry st set clock . if it won;t set / replace it . it has gone bad .mm
Dec 09, 2009 | Maytag 24" Built-In Single Electric Wall...
Digital clock will not stay on.
Hi
I hate to tell you but the timer is failing.
If you can give me any model and serial numbers i will find a replacement price for you.
regards
aardvark Repairs
aardvark.repairs@btinternet.com
Nov 17, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Timers on my aeg competence cooker
Hi, My Competence B1180-4 digital clock keeps switiching itself off and then back on. This means that the timer etc dosen't work. It is intimitant.
Aug 10, 2009 | AEG B1180-4 Electric Single Oven
Oven will not stay on
HI. this is a control fault that can be confirmed by unplugging the unit for 5 minutes. if the control continues to cycle from auto to manual, replace the control board(EOC/Clock)
May 28, 2009 | Ovens
The oven won't come on, the digital timer just flashes continuous
Hi
have you tried setting the clock as the oven wont work if the clock is not set. hope this helps
regards dan
Mar 19, 2009 | De Dietrich UMP404 Powerclean Stainless...
Maytag 24" Built-In Double Electric Wall Oven - Stainless-Steel Logo
12 people viewed this question
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
