Question about Sears Washing Machines
Fdl door lock wont work
  • 2,119 Answers
Posted on Sep 05, 2014
What is code FDL
FDL code is a door lock code on these washers, but be advised, the older models had an issue with the main control boards loosing connection at the soldered joints for the door switch. They would loose solder, and the board would think the fault was the door lock and it was actually the board.
Nov 11, 2013 | Kenmore Elite 45986 Front Load Washer
Flash FDL code
Fdl error code means a "door lock error code".
This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code. In order to solve it, your door lock switch needs to be replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day
Dec 19, 2011 | Washing Machines
Fdl code
Your door lock switch needs to be replaced... Fdl is a door lock error.code. This error shows up because the door cannot be locked. The door will try to lock six times before displaying the error code
You can order a new part replacement from the Sears PartsDirect website.
Hope helps.
Sep 25, 2011 | Washing Machines
GIVING CODE FDL?
If the door fails to lock after six (6) attempts "Fdl" will display. The "Fdl" error code indicates the door failed to lock or the control does not detect the door being locked. The likely failure is the door lock mechanism. There is always a chance there could be a loose wire connection between the door lock mechanism and the Central Control Unit (CCU) causing the error too.
Jan 22, 2011 | Kenmore Elite 45986 Front Load Washer
Door will not lock and code on panel reads"F" then
I added the instructions in the image below on how to remove and replace the door lock mechanism. NOTE: Disconnect the power cord from the power source before removing and replacing the door lock assembly.
Jan 09, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What causes fdl?
FdL = Door lock error
Possible Causes
 Door Lock Mechanism broken or removed from the Door,  check Door Lock/Switch Assembly,  check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU),  door Lock/Switch Assembly Failure
Replace failed component.
Jul 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
FDL fault code on kenmore elite washer
F DL
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Nov 08, 2009 | Kenmore Elite 45986 Front Load Washer
F dl blinking and machine wont run
Fdl is a code that indicates a door lock error. This error occurs because the door cannot be locked. The door will try to lock six times before displaying the error code. You have a faulty door lock switch. Hope this helped and best wishes.
Aug 27, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet says Fdl washer wont turn on
F/dL ERROR IS FOR :-- Door Lock ErrorA Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
TO RESOLVE THE PROBLEM :---
Door Lock Mechanism broken or removed from the Door globul1a.gif Check Door Lock/Switch Assembly globul1a.gif Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU) globul1a.gif Door Lock/Switch Assembly Failure
May 06, 2009 | Whirlpool GHW9400SU Front Load Stacked...
Kenmore elite he3 - door lock
If sound like a lid switch issue. Open the top of the washer to get an access to the lid switch(located near the doorframe). Look for a loose wire or a broken switch. In case there is no loose wire or broken switch, you should replace the switch. Good luck!
Sep 05, 2007 | Kenmore Elite 45986 Front Load Washer
Washing Machines Logo
80 people viewed this question
Top Sears Washing Machines Experts
Fred Sops
Are you a Sears Washing Machine Expert? Answer questions, earn points and help others
