Question about GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ...
Frig gets too cold freezer works good
Experimented with changing set temp nothing works
I had the same problem. I have the side by side Profile Artica. The problem was a broken damper. It allows the cold air in from the freezer side. With it broken, there was a steady flow of freezer air coming into the frig side. It was easy to fix. I ordered the part (damper/fan assemble) for around $100. While searching for a solution, it seems that this is a common problem. Unfortunately, I received a wide range of incorrect solutions to the problem which could have cost me a lot of money. I hope this helps!
Posted on Aug 03, 2009
I have a Frigidaire model# FRS26H7CSB1. THE FREEZER IS NOT GETTING COLD ENOUGH AND THE FRIG IS COLD BUT ONLY WHEN SET TO LOWEST TEMP SETTING. The metal frame/pillar between the freezer and frig is very...
The freezer not getting cold enough is defiantly due to the condenser fan motor not working. You would be best served to replace the fan motor with the correct part number though others will work, a small desk fan blowing in the back would work. As to the temperature issue in the refrigerator, you might have a bad t-stat.
Mar 12, 2013 | Frigidaire Refrigerators
Freezer not cold enough
setting the freezer at 7 opens the baffle from the freezer to the fridge to make the fridge colder. It works completely opposite than a person would think. Feel in the back of the fridge with it on this setting. The freezer is dumping all its cold air into the fridge thus equalizing the two parts. if you move the selector to 1, you should feel the air from the freezer cut off in the fresh food compartment. try a setting in the middle and let sit for 24 hours. Hope this helps
Jan 25, 2012 | Amana Refrigerators
The temperature is set correctly but the top portion of the refrig does not stay cold (and goes up to 60 degrees) while the freezer gets too cold (and goes to -11). We cleaned the vent on the motor and...
Sounds like the ductwork inside the fridge that connects to the freezer is either partially blocked with ice or the damper flap is stuck in that duct.Please let me know if this helps, a good defrost should cure it if it is
Jan 19, 2011 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
My double door frig gets its air passage blocked again and again with ice and it stops cooling. When the ice is cleared either opening the freezer back, or shutting it down, frig starts working, but in...
Hi!!
Let's try this:
Check temp. settings the freezer knob controls thermostat settings, set it about one third of the scale.
The fridge knob, (set it half way) controls a door actuator that lets cold air blown by the little fan in freezer go from evaporator (the one that gets iced up) to the fridge, so, the little fan in freezer is the one in charge of making your fridge work. CHECK FAN, it should come on when you open freezer door for a couple of minutes, it must sound strong, and if you put your hand in front of one of the fridge's air vents you should feel cold air coming out, if no or weak breeze comes out, check passages for obstrucion, if none, replace motor, (about 20 at your hardware store)
I assume your mechanic already checked thermostat and defrost operation, because, if your timer is right, the defrost mechanism will de-ice the evaporator about four times a day.
Check your drain hose for blockage.
Let me know how it worked out, good luck.
If helpful, click below
Apr 03, 2010 | GE GSL22JFR Side by Side Refrigerator
Everything in my frig is frozen
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .. I don't know what he was doing with the putty unless he was stopping up the vent which won't work because you have to have the air circulation for the fridge section to work. The fridge temp control may be the problem.
Aug 14, 2009 | Maytag MSD2456G Side by Side Refrigerator
Upper freezer temp. alright Lower refrigerator to
Sounds like the airflow balance is off. When you turn the aircontrol to max what you are actually doing is starving the frig compartment of cold air, cold freezer, warmer frig. It is recommended to set both controls to middle and see if it helps the problem.
Jul 30, 2009 | Whirlpool Refrigerators
We have a LG Two Side Fridge.
Look for the air ciculation regulator sliding vent between frig & freezer section open accordingly. Set both sides to #3 on dials if frig not cooling to less than 40 degrees, might need new cold/temp controller behind frig dial
Apr 30, 2009 | LG LRSC21934 Side by Side Refrigerator
I have a Kenmore coldspot side by side- not cooling properly
Setting it to 5 is what the manufacturer recommends. If you set it to 1 and the frig is still not cold, then you probably have a faulty cold control (thermostat)
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Freezer is freezing but fridge is not cold as it was
Sounds like defrost timer is not putting the refrigerator in defrost every 8 hours. You freezer should be below -5 degrees. Also the condenser beneath the refrigerator possibly needs cleaning. First slowly turn the defrost timer clockwise until freezer goes in defrost. You should hear the sound of crackling noise in freezer after about one minute into defrost. If timer does not come out of defrost or does not turn itself then replace it. Let me know what you find, Thanks Sea Breeze
Feb 07, 2009 | Frigidaire FRT15G4B Top Freezer...
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
GE Profile PFS22 33" Artica French Door Refrigerator w/ 22.2 Cu. Ft. Capacity, ClimateKeeper System ... Logo
245 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
