10 cm to inches in knitting table
I'm knitting and there is a test pattern knitting 18 st for 25rows to 10cm?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Office Equip... Master
  • 102,366 Answers
One inch is exactly 2.54 cm, so 10 cm is about 3.94 inches.
Posted on Apr 20, 2014
Pattern "Simone" in Neck Effects book - should Rows 2,4,6 be purl instead of knit? It says it is stockinet the but if you knit it will be garter stitch
Then knit purl to keep stockinet st. unless it changes in the pattern. what does the picture look like?
Feb 09, 2018 | Sewing Machines
I need to convert 5'4 into Centimeters?
Here is the math info, you do the math.
One mm is one "millimeter" or one one-thousandth of a meter (1 mm = 1/1000 m).
One cm is one "centimeter" or one one-hundredth of a meter (1 cm = 1/100 m).
Therefore, 1 cm = 10 mm. To convert mm to cm, divide the number of mm by 10 to get the number of cm
Jan 23, 2017 | Office Equipment & Supplies
What does RS stand for in a pattern (?)
Usually the knit side is the right side, but sometimes the purl side is used for the right side. When this is done it is called reverse St st. When a pattern tells you to work in St st, it means to alternate a knit row with a purl row.
http://www.craftyarncouncil.com/tip_knit.html
What does RS stand for in pattern Google Search
Dec 03, 2016 | knittingdaily.com
What size needles for bulky/12py wool?
It depends on your project. You need the size needle that will give you the stitch width and stitch length called for in the pattern. The pattern calls for a specific gauge, so you'll need to try out different needles, knitting a swatch on each needle size, and counting the number of stitches across and down to match the pattern specification. Does the pattern not give you a needle size? Needles come in either straight or circular in all various sizes as long as you stay within the same brand needle. (Needle brands differ from one to another, so try to stay within only one brand.) So a straight needle size 6 should be the same size as a circular needle size 6 (of the same brand).
However, although it may call for a specific size needle, you will still need to knit some test swatches because knitters usually knit looser or tighter, so one needs to adjust the needle size to accommodate those differences, ie someone who knits tightly may get 8 stitches to an inch, but a loose knitter may get only 6 stitches. But if the pattern says to cast on 48 stitches in for row 1, that means the 8 stitch gauge will yield a project that measures 6 inches wide (48/8=6). But a 6 stitch gauge will yield a project of 8 inches wide (48/6=8). The result would be one project will be 2 inches wider than the other.
But that is only half of the problem as you would still need to measure the number of rows per inch to get the length of the project. If there are more rows to the inch than specified, a garment with say an armhole that may be too small. If there are fewer rows to an inch, the result may be an armhole that is way to big.
Be very careful with your pattern and yarn selection. You will be much more successful if you stick to the number ply and yarn weight specified in the pattern, ie if the pattern calls for 2-ply 2 oz yarn, there may be some particularly difficult issues with substituting a 4-ply 4 oz. yarn. You may end up with a project that will not fit. For instance, you wouldn't want to use a heavier yarn to knit a baby garment. Baby garments usually call for baby yarn which is a specific ply and weight.
How to Measure Your Gauge in Knitting
earthguild com
3 Things You Might Not Know About Knitting Gauge Adjustment
Oct 30, 2016 | Sewing Machines
Trou ble with chain knit scarf/pattern
This question should really be asked at a knitting site. Try your question here where the pro knitters hang out.
http://www.knittinghelp.com/
Jul 19, 2012 | Sewing Machines
Hi, I have a Bond Sweater Machine, I need to recalculate the stitches and cm. from a hand-knitted sweater with a knitting machine. I know it can be done, it's something to multiply and divide, get the...
Hi. I have a Bond, too. Even if you get a formula to recalculate the numbers of stitches per inch/cm I would suggest that you do a gauge swatch with the Bond before you start knitting the actual sweater. There is a terrific group of fellow Bond machine enthusiasts and experts here: https://groups.yahoo.com/neo/groups/incrediblesweatermachineclub/info
They have free patterns, tips, and advice. They have some manuals posted, too. :)
Jul 10, 2011 | Bond-America Ultimate Sweater 01008-9
What does tw3 and - mean in a knitting pattern
TW3 is twist three. Slip 2 and knit 3rd st on left-hand needle, knit 2nd st, then knit 1st st and slip all three from needle together.
Jan 28, 2011 | Kitchen Ranges
57 people viewed this question
k24674
jasbo
jasbo
