Question about Navman GPS
Alarm wont stop going off - Navman GPS
Alarm wont stop going off. Car wont start. Any way to disable it?
Plug your ears first, open the car with key, open the bonnet to get to the battery, disconnect one battery terminal and cover this with rag to avoid a short circuit. That should reset everything - alarm, radio. Do not lock the car. After an hour reconnect the battery. Hopefully alarm will have reset and then use the key in the ignition. Hopefully starts but you should buy a replacement button for your car and security system. If alarm sound again, disconnect battery again and call an auto electrician.
Dec 31, 2014 | 1995 Honda Accord
My 2000 grand vitara alram wont stop going off what can I do to stop it
a lot of times car alarms go off when they since a voltage drop in the vehicles battery test or replace cars battery
Jun 01, 2012 | Excalibur. K9-MUNDIAL-SS Entry Level Auto...
My 98 vw jetta alarm wont stop going off
Maybe your key remote batteries need to be changed. Also have it scanned for DTC's which I believe you may have quite a few stored in memory, problems you weren't aware of.
Sep 20, 2009 | Volkswagen Beetle Cars & Trucks
Car wont start
Sounds like you have a shorted wire causing a drain. I recommend disconnecting the alarm all together which should stop the short so battery can remain fully charged.
Jul 09, 2009 | Hyundai Motor 2002 Sonata
Cant get the factory alarm to stop going off .
Look up drivers side dash to the left look up should be a little box with wires, unplug one at a time make sure the truck starts after each wire unplugged. My nephew had the same problem on his Jeep. Alarm is tilt sensitive. Neighbor had the same problem on his GMC.
Mar 26, 2009 | 1995 Jeep Grand Cherokee
Car alarm wont let me start the car it wont stop going off
try unhooking the battery while the battery is disconnected turn the ignition on leave the ignition on while you reconnect the battery this should override the alarm
Jan 31, 2009 | 1994 Volkswagen Golf
GPS Logo
26 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
