Question about Audio Technica Audio-Technica MB 4k/c Microphone
How tointerface an audio technica mb 4k to computer
Is it possible to hook this mic up to a computer mic input (Compaq Pressario desk top) without going through a mixer, cable only? i am cuurrently going through a fostex mr8 and i have to pretty much swallow the mic to get a good signal from the mr8 output, the mic however seems to have a very good output. thanks - jim keith
  • 3 Answers
As long as the microphone is getting power (via a seperate phantom power unit, or using batteries, the MB 4k can use AA) you should be able to plug into a computer with no trouble, as long as a couple other things are set. You'll need two things in addition to your mic and battery.
1) You need an adapter to go from XLR to 1/8". Go to www.sweetwater.com and search for "XLR to 1/8". They are around $10.
2) Your computer must have a "mic" level input. It is probably a red connector. If your computer only has a "line" level input (probably blue), then you will have to use the mixer, or some in between unit to up the output of the mic to line level.
Not sure why your mr8 is outputting so low. Make sure you have phantom power turned on.
Best of luck!
Posted on Jun 28, 2009
Pro 70 lavalier mic- is there away to hook the pro 70 lavlier directly to your computer or mic WITHOUT a mixer or amplifier?
On microphone input of your soundcard if it is not there then sorry you need a tiny amp as the other inputs are all at line level
Jan 22, 2014 | AUDIO-TECHNICA U.S. INC. PRO 70 Cardioid...
Connection
if it plugs into the line in or mic in using the 3.5 mm plug then no, the mic won't need a driver. Your playback and recording devices on your computer DO need drivers. Sounds like a computer config issue to me. Could be a few different things
Oct 14, 2013 | Audio Technica Audio-Technica ATR-20...
I have a low level hum in the MIC like a motorcyle in mt AT 4040
Remember this is a condenser mic that REQUIRES phantom power. There are several failures regarding this phantom power delivery that COULD cause your problem.
A "LEAKY" mic cable that is not a fully balanced cable can cause the problem. Test with another cable to exhonorate your cable.
A failure of the input bypass caps in your amp/preamp can cause the input to become unbalanced and let in hum.
A phantom power that is improperly filtered can also cause this. Test using a different source of phantom power.
Remember that you can easily get feedback that may oscillate like hum if you have a monitor speaker anywhere in "earshot" of the mic. They are very sensitive and intended for studio use.
Sep 26, 2009 | Audio Technica Audio-Technica AT4040...
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Feb 21, 2009 | Audio Technica Audio-Technica AT2020 -...
No volume from Audio-Technica ATM410
the mic you mention is a dynamic mic, and needs a mic preamp to get decent levels for most computer sound inputs
Nov 26, 2007 | Audio Players & Recorders
Want work
You need to fine tune (to connect wirelessly) ur wireless mic to your wireless receiver unit. Put a fresh battery to ur Mic then power-up ur receiver unit, find the right channel for both unit.
Aug 05, 2007 | Audio Technica Audio-Technica DR2600...
Audio Technica Audio-Technica MB 4k/c Microphone Logo
95 people viewed this question
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Morne Olivier
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
