Question about byD sign d:5032 50 in. HD-Ready Plasma Television
SSL Error Can't fix it how to fix ssl error problem?
What does 'SSL communication cannot be performed a handshake error has occurred in SSL' mean?
The Secure Sockets Layer (SSL) protocol uses a combination of public-key and symmetric-key encryption. Symmetric-key encryption is much faster than public-key encryption; however, public-key encryption provides better authentication techniques. An SSL session always begins with an exchange of messages called the SSL handshake. The handshake allows the server to authenticate itself to the client by using public-key techniques, and then allows the client and the server to cooperate in the creation of symmetric keys used for rapid encryption, decryption, and tamper detection during the session that follows. Optionally, the handshake also allows the client to authenticate itself to the server.
If you get the error you can do the following
1. Go to your internet options
2. Go to security settings tab
3. Click on Trusted Site's
4. Add https://THE NAME OF WEBPAGE YOU A GETTING ERROR FROM
5. Go to Advanced tab
6.Scroll down to USE SSL 2.0 and USE SSL.3.0 make they are both selected and click Apply button at the bottom
Apr 21, 2016 | Computers & Internet
Had a power outage, line down in the neighborhood. Tried to get back on computer, Google is blocking with an SSL error
Sounds like a connection error, maybe your internet is down still or you need to restart your modem and router. Here is some google help though just in case.
Check secure connection SSL error
Apr 20, 2014 | Microsoft Windows Vista Home Basic for PC
Ssl error
go to google settings upper right of your google chrome then settings then unchech ssl and also in internet option you can ucheck ssl certifacate check
Mar 24, 2014 | ASUS Sabertoothz77 Sabertooth Z77 Lga1155...
Error 107
Try this tip:
Go to option ' proxy settings and the standard MSIE window will pop up. Then go to advanced tab and be sure to tick:
USE SSL 2.0
USE SSL 3.0
USE TSL 1.0
If problem still occurs then you need to fix internet connection and windows invalid registry entries.
Use system utility tool Intel Software Partner Reginout that will not only fix registry errors but will also Optimize Internet by running its Internet Optimizer feature.
Oct 03, 2012 | Mozilla Firefox
How to fix Error 107 in google
Its more to do with the Certificates and the bset way to Tackle it is to Enable SSL 2.0 and disable SSL 3.0. The steps are as follows,
Step 1 : Launch Internet Explorer.
Step 2: Click on Tools and Internet Options.
Step 3: Click on Advanced Tab.
Step 4: Look for SSL 2.0 and 3.0
Step 5: Usually you will have SSL 3.0 Checked. Uncheck it.
Step 6: Check 2.0 Click apply and Close.
Hope this helps.
Nov 17, 2010 | Computers & Internet
Ssl error appears
The solution in the first case is to purchase a private SSL certificate which is issued for the specific domain by a trusted authority.
The solution in the second case is to have the SSL certificate reinstalled with the correct CA bundle. The CA bundle is provided by the SSL vendor and should be included in the private SSL package.
Jul 29, 2010 | Computers & Internet
While accessing mail i am getting message (error code:ssl_error_rx_record_too_long_
Error code: ssl_error_rx_record_too_long Your SSL website may fail to load and display the error
This usually means the implementation of SSL on your server is not correct. The error is usually caused by a server side problem which the server administrator will need to investigate.
Below are some things we recommend trying.
- Ensure that port 443 is open and enabled on your server. This is the standard port for https communications.
- If SSL is using a non-standard port then FireFox 3 can sometimes give this error. Ensure SSL is running on port 443.
- If using Apache2 check that you are using port 443 for SSL. This can be done by setting the ports.conf file as follows
— clip —
Listen 80
Listen 443 https
— clip —
- Make sure you do not have more than one SSL certificate sharing the same IP. Please ensure that all SSL certificates utilise their own dedicated IP.
- If using Apache2 check your vhost config. Some users have reported changing <VirtualHost> to _default_ resolved the error.
Mar 18, 2010 | MPC Computers ClientPro 125D PC Desktop
Getting error on e-mail. Says
try these servers:
Incoming (pop3)
US - plus.pop.mail.yahoo.com SSL 995
UK - pop.mail.yahoo.co.uk SSL 995
AU and NZ - pop.mail.yahoo.com.au SSL 995
Outgoing (smtp)
US - plus.smtp.mail.yahoo.com 465 TLS
UK - smtp.mail.yahoo.co.uk SSL 465 TLS
AU and NZ - smtp.mail.yahoo.com.au SSL 465 TLS
Oct 14, 2009 | Computers & Internet
Error message:"Unable to establish a secure connection"
This error can occurs because the VeriSign Certificate Authority (CA) has changed the hashing algorithm that is used for new Secure Sockets Layer (SSL) server certificates from Message Digest 5 (MD-5) to Secure Hash Algorithm 1 (SHA1). A supported fix is now available from Microsoft for Windows CE 2.11 and Pocket Explorer 3.0 this fix can be found at: http://www.microsoft.com/mobile/handheldpc/downloads/128bit.asp Note: After you have downloaded and installed the fix, be sure to soft reset the device.
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
byD sign d:5032 50 in. HD-Ready Plasma Television Logo
15 people viewed this question
Top byD sign Televison & Video Experts
Jaime Hernandez
Elise Lacoursiere
Elise Lacoursiere
Are you a byD sign Televison and Video Expert? Answer questions, earn points and help others
