Question about GE Refrigerators
What direction does the fan go on on a ge tdc18
2 Suggested Answers
  • 7 Answers
SOURCE: ge profile refrigerator tdc18 aabb, freezer works
Bottom freezers are notorious for icing up. We inherited two ge freezers and both had this problem every few years. Always try unplugging for 12 hours then waiting 30 mins before trying to service. In most cases it is just bad design or bad seals on the doors building up ice.
Posted on Apr 29, 2011
My ge xl1800 has 50 volts at the fan when the fan switch is off. it hums because of the low voltage. it works fine when the fan switch is turned on. the fan cap checks out fine
If you have had trouble with the cooktop lights recently, or if you get a hum or buzz in the area of the control panel assembly when you open the door, either indicates that you need circuit board repair. More details here.
Jan 30, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Ge Profile Electric dryer model DPSE810EG5WT The
Hi.
If the fan does not work at all,then the fan motor must be replaced. The fan is tested jumping its contacts to energize it directly.
More commonly the problem is clogged air ducts. Check lint filter and check ducts for blockage. Ensure that the air duct is well in place.
Jun 27, 2010 | Dryers
Ge profile refrigerator tdc18 aabb, freezer works but not the cooling section
May 27, 2010 | GE Refrigerators
Refrigerator not cold
Your problem could be a defrost component issue (e.g.: defrost thermostat, defrost heater(s) or defrost timer). Contact an appliance service company.
Apr 13, 2010 | GE Profile PSW26P Stainless Steel Side by...
Blades on fan became brittle and broke off.
replacement fans can be bought for your microwave. there are also metal one available, Contact Sears or GE direct
Please rate my help++++Thanks for using FIXYA
Nov 27, 2009 | GE Microwave Ovens
How do I reverse the direction that my condenser fan is blowing?
You would have to replace the fan blade with one with the opposite pitch. In other words a fan that is a mirror image of the one in place. You cannot reverse the flow by flipping the fan blades over.
Why do you want to reverse the direction? I can think of no benefit in doing so. But then again you posted this under a Water Filtration heading?
Jul 17, 2009 | General Electric GE SmartWater Household...
I have GE TFX25JRBB. Recently it started work not
Looks like you have a defective defrost heaters..or defrost thermostat...
Here is what you need..
:Heater WR51X443 and thermostat WR50X122
Jul 31, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Refrigerator external fan - air flow?
This really depends on the manufacturer and their preference on design. First, the fins at the compressor are part of the condensing coil. Most all makers have air pulled into the condenser coil and blown across the compressor. You should be moving room temerature air across the condenser and the air from that is usually then moved across the compressor.
Hope this helps clear it up .
May 08, 2009 | Refrigerators
GE Microwave vent fan replacement
(I'm assuming you're talking about the hood / vent / exhaust fan instead of the internal magnetron cooling fan).
The part # SMV-260UA-C will not be enough to go on, as there at least 3 variations on that number shown at Samsung parts.
These microwaves are made by Samsung, but you'd need the GE part number to replace the whole thing. They don't sell the blades separately.
The part # for the "ventilation motor" is WB26X10042 and you can find it for $97.11 here, which is about fifty dollars less than direct from GE.
I may have available a replacement flan blade off a used unit. If you'll send me the dimensions, I'll check. I need the length of the fan blade, the diameter, and the inside diameter / shaft size, and whether the shaft is round or "D" shaped.
Please feel free to contact me directly.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Jul 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Refrigerators Logo
15 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
