Question about Lexmark X5470 All-In-One InkJet Printer
When trying to send a fax I keep getting phone line errorand when i print from the internet the text comes out as gobblygook
If you have you phone service thru an internet provider like Comcast, or Roadrunner, typically speaking, anything other than a POTS system with analog copper wires can be the problem. (i would have referred to this as a VOIP system, BUT, CABLE AND ISP PHONE SERVICE ALTHO IT IS A DIGITAL TRANSPORT, IT IS NOT TRUE VOIP).
Here is your fix--- set your baud rate on the fax to the lowest setting, usually 1400 bps. If you dont know how to do this consult the owners manual, be aware, not all fax machines are capable of baud rate adjustments.
Posted on Jun 26, 2009
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
Have an HP Laserjet M1319 Fax Machine. Fax line appears to be working but I can't send or receive faxes. It shows"receive" when they come in, but won't print them up.
Sometimes these machines will give you automatic messege "Recieve."
If this is only plugged in the fax machine, can you hear the machine dialing or hear the machine recieving a dial tone?.
Some machines have the audio sound turned off, so it is quiet when the machine is doing fax transmissions to limit the noise.
If you can turn it on you can make this eaisier to resolve. If it is on then you can make this more simplier.
Make sure the settings are set right, Junk mail turned off, set up the fax answer mode to print, and not store, check to see if the auto confirmation can be turned on. When this mode is turned on for this process at least you can get a print out on the fax copy, some will give an error messege.
If you can put an analog phone into the fax line, use another phone to call that number and see if it rings. This will ensure the phone line is working well.
If this line has a phone line converter, digital to analong, this may cause some of the issues. More and more people are trying to use the internet as their phone line as a fax.
I would like to know if any of this resolved the problem. There are more questions I have to this type of problem.
Good luck.
Oct 16, 2009 | HP Office Equipment & Supplies
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Can't send a fax.
You need to have a phone line not just internet connection to send a fax. Unless you have an account with a fax to email company. So you need to hook your fax machine up to your already exsisting phone line, get a seperate phone number for fax purposes or serch the internet for a fax via email company.
Jan 14, 2009 | Lexmark P4350 All-In-One InkJet Printer
Keeps printing pg 1... sender's machine says it isn't going thru
Press
Function
7
monitor key slowly 4 times
6
scroll down to SHIPMENT SET
set
set
wait for the machine to reboot
Jan 13, 2009 | Panasonic Panafax DX-800 Plain Paper Laser...
Fax won't work with new digital/internet phone system
True. ALL fax machines are analog devices. Internet phone lines are DIGITAL.
There is no way to make it fax reliably.
Dec 29, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Sharp Inkjet UX A 1000
I had the same problem and, like you, went to the internet to find a solution. One answer I found was to unplug the vax, wait one minute and then replug it. This didn't solve the problem for me. Out of desperation, I printed the fax "Help" pagea nd, lo and behold, after it printed my Sharp 510 Fax was back to normal.
Nov 04, 2008 | Sharp INKJET FAX UX-A1000
Can't send fax
Greetings,
Seems that you accidentally ended the chat session.
Here's what i got, your phone service is on VOIP
VoIP is voice transmission over a broadband Internet connection instead of a standard phone line. Basically, Vonage converts your voice into data and sends it like an email.
Fax machines, like yours, are designed to work with the regular phone lines. As your phone line is digital, the functionality of your all-in-one printer & fax cannot be guaranteed.
Vonage also offers a dedicated fax service and you might want inquire them about that.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Canon PIXMA MX310 All-In-One Printer
What's up; could it be the phone line?
yup, noise coming across line will do that, have it checked. Could be sending partys line being noisy too, you could also hook up a phone and listen for crackles/noise on line.
99 percent chance it is noisy/poor phone line.
Nov 09, 2007 | Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
110 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
