Question about Kenneth Cole Watches
Kc 9181 Second hand not moving
If the Chronograph is running, the second hand may be paused as on of your dials is recording seconds instead of the larger second hand. You shouldn't be running the chronograph timing all the time.
Jan 13, 2016 | Watches
WHY DOESNT THE SECOND HAND MOVE?
It probably isn't the second hand, but the sweep timer hand that is only used in Chronograph mode. If it is indeed the small second hand down at the bottom of the watch face, try pulling the crown, and moving the hands and then depress the crown again.
May 10, 2015 | Oakley 12 Gauge Chronograph Stainless...
Swatch diaphane second hand stuck
Hello, a week ago the small second hand (not long chrono second hand) got stucked and my irony swatch just stop moving. Although the chronometer could be running if started... The small hand just didn't move.
I tried different tricks, like removing battery, pull out main wheel and use chrono buttons to reset arms. Etc.
Today I noticed that when turning the wheel backwards a couple of times (one or two hours back) the little hand moved one second back... Pushing wheel back to On possition made the small hand move forward one second and get stucked again.
Then I did this procedure a couple of times, at some point I turned the wheel back for a while (may be 5 full turns) and noticed the small hand moved more than one second (5, 10, 15 seconds backward)... when I noticed it was moving freely I pushed wheel to on position and noticed the small second hand was running normal.. I hope it works for some of you. Greettings from Canada
Nov 06, 2012 | Swatch Diaphane Chronograph Blooded Silver...
I recently bought a Kenneth Cole KC 3790 as a gift and I am tying to set the date...the date is presently Saturday 27th February and I am having difficulty getting to the 27th day of February on the...
Pull out crown to the time setting position (second click) and set time to 5.30 pm or am. Push crown back completely. Pull out crown to the date setting position (first click) and set it to 26th, then pull out crown further out to the time setting position (second click) and adjust watch hands forwards until the date changes to 27th. Date is changing at midnight, so, continue to adjust hands forward to the right time. Rate me, plz.
Feb 27, 2010 | Watches
I have a kenneth cole kc 3775 watch which is automatic when move the watch from side to side the minute hand moves will this be fixed under the lifetime warrnty and what is wrong with this watch
Yes it will fixed under warranty,because its only a little problem.They are only going to place minute hands tightly so it will not lose again.
Hope it may help you;
Regards;
VOTIT
Apr 22, 2009 | Watches
Second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
Jan 03, 2009 | Seiko Kinetic watch
Festina 16177 / 8- Tour de France 2005 - second hand not moving
The large sweep hand is not the second hand,it is the 1,100th sec hand on chrono.The second hand during time mode is the small dial at the bottom which should be going round
Jul 22, 2008 | Festina 16177 3 Watch
The second hand is not moving
make sure your mode is on time and not calender. if on calendar it sticks on the present month and does not move.
May 24, 2008 | Watches
Watches Logo
23 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
