Question about Coleman Mach III Air Conditioner
What type of freon does a lennox cb29M elite series use?
    Genius:
  • Coleman Master
  • 1,363 Answers
R-22
Posted on Aug 20, 2015
My lennox elite series cb29m-41-1p is leaking alot of water in the house with the air conditioner on. drain line to outside is clear
The condensation pan in the unit must have no cracks our brakes, and needs to be tilt down toward the condensation drain line, algae builds up clogs and must be cleared of clogs periodicaly
Aug 05, 2017 | Heating & Cooling
Lennox elite heat pump throws cold air
The unit should give you an error code if something is wrong.
Here's the manual:
http://instalacionesindustriales.com.gt/pdf/Lennox_Minisplit_HE.pdf
Mar 25, 2014 | Lennox 7 Series MS7-HO-18P MS7-HI-18P Heat...
Lennox codes
I have a gas Lennox elite furnace & code light is not turning on
Jan 13, 2014 | Heating & Cooling
Lennox mod#G12Q3E-82-4 gas heater. fires,runs for about 2min and shuts off.
Lennox Elite series. Check the back of the controller circuit board for a short to the back of the metal enclosure. I found a relay pin was shorting to the metal enclosure and melted the circuit board. Nice design huh. I repaired it by re soldering the relay pin back to the board, beating out the back of the metal box to gain some clearance, and putting insulating tape between the circuit board and the metal box.
Nov 04, 2010 | Heating & Cooling
I have a Lennox CB29M Air Handler with an electric heater, which is used to heat the lower two rooms of my house. The handler unit is located in a mud room right behind the back patio. I'd like to get an...
Any of these Lennox dealers can help you choose a compatible HS29 or HP 29 condenser and evaporator coil to match your system.
http://www.lennox.com/locate/default.asp
Jul 06, 2010 | Heating & Cooling
Why would my heat pump central air blow cold then warm
Sounds to me like you have wiring issues. Need to make sure all your connections are tight, wires are clean and free of bare spots (possibly from rodents chewing them)and your settings on your tstat are correct. Heat pump with back up electric heat.
Jun 09, 2017 | Heating & Cooling
Water is leaking into my garage when a/c unit is running. Lennox elite series cb29m-41-1p
Check your indoor unit. your problem is there. you will be able to see where the leak is coming from then I would be able to help you more
May 19, 2010 | Heating & Cooling
The fan is running and blowing cool air out of the unit but there is no air coming through the vents, what are the possible problems? (Lennox Elite series)
The unit could possibly have a frozen indoor coil. Turn ac to off...and fan switch to on...wait 45 minutes and see if air flow improves. Check for dirty filter which can lead to freeze up. Low on freon is also a possibility.
May 18, 2010 | Heating & Cooling
I got a lennox xc13 air condtitioner,not blow cold air
When was the last time you checked or had the freon level checked.
Aug 02, 2009 | Heating & Cooling
Lennox Elite Model # CB30M-65-4P I had my A/C fixed while back because the freon lines keep hitting each other from the vibration which causes a leak in the line every 6 months to a year and since then...
The copper the big line should have a insulating foam wrapped around it called rubetex which eliminates any rubbing. They should never be that close also. Now is this unit a heat pump?
Nov 24, 2008 | Heating & Cooling
Coleman Mach III Air Conditioner Logo
113 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
