Question about Vizio E550i-B2 55" LED TV 1920x1080, 120 Hz, HDTV
Can't get it to turn on
Switched from a 32 inch hdtv to this new 55 inch hdtv. everything was put back in the same spots, cables that is and it wont get any picture. " no signal" is all we get. does the remote need to be programed?
  • 6 Answers
SOURCE: vizio hdtv 32 inch wont come on.
More then likey you have a bad mainboard. Especially for the 32inch and below its usally the mainboard rather then the powerboard.
The tv parts are modular you can usally buy parts on ebay. I dont recomend soldering or anything like that, just a simple board swap will do.
Posted on Jul 19, 2009
  • 8457 Answers
SOURCE: Vizio 32 inch hdtv, Motorola DVR box...Whenever I
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Posted on Mar 19, 2010
UpGrade
  • 113 Answers
SOURCE: How do you replace a remote sensor in Vizio 32
Pull the back off of the screen and look at the bottom between the two speakers you will see a little box with a few wires going off to one of the printed circut boards. I have never seen one fail before, most of the time its the remote/dead batteries etc.
Posted on May 22, 2010
budmrtn
  • 11361 Answers
SOURCE: Can't see picture
You either have bad 24vdc power supply or shorted out backlight inverter board, those are the two place to look, dead T-CON board can cause no picture on the screen, the screen will glow slightly.
Please read on:
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Posted on Jul 28, 2010
  • 8457 Answers
SOURCE: the picture on my new 55" lcd hdtv overlaps the
Find a buttons on ur tv remote control that said like VIEWMODE,P.size or a Zoom.Push one of these buttons to find the wright picture mode to fit in ur tv picture screen frame.
Posted on Nov 22, 2010
Samsung UN32F5500 32-Inch 1080p 60Hz Slim Smart LED HDTV -- turning on and off, fix?
sad to inform you but we do not have any parts for anything here on FIXYA.COM .
Nov 05, 2015 | Samsung UN32F5500 32-Inch 1080p 60Hz Slim...
Samsung screen goes grey with green letter? Have Comcast cable
When the green letters appear, turn off the cable box only.
If the screen changes, the problem is in the cable box or hookup.
If the letters stay, there is a problem in your TV.
Jan 09, 2015 | Samsung 6030 Series UN55FH6030 55" LED TV...
Red spots screen
you have one of the cables in the wrong input. keep trying till you get it right
May 07, 2013 | Haier HL32D2 LCD 32-inch TV with piano...
I have a hitachi DLP tv and i replaced the lamp in it but now it wont turn on and the lamp light at the front blinks red?
It could be a problem with the new bulb, the lamp ballast or the safety switch. You made sure and put all the covers back on after replacing the lamp right? If not there's a safety interlock switch that will prevent the set from coming on.
May 24, 2010 | Hitachi 55VS69 55" Projection HDTV
I have on Sony KDF55E2000. 55 inch projection. Power wont stay on
It is clear symptom that lamp is near to end of its wroking life and tv needs lamp replacement.
Please replace lamp in tv to get it back in business. Lamp replacement procedure would be written in user manual and its easy.
Please buy Sony original lamp for good picture.
Let me know if you have additional question.
Thanks.
Apr 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
No signal when hooked up with a digital cable box
turn your tv to channel 3 and then try 4 one of these should work . Also make sure that you have it plugged in the right coax jack in the back
-Josh
Mar 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio E550i-B2 55" LED TV 1920x1080, 120 Hz, HDTV Logo
37 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
