Question about Dometic Rooftop RV Air Conditioner
My duotherm 59136.521 freezes up quite often. what are the possible problems &solutions?
  • gerwingdr Jun 21, 2009
    On a roof top a/c how do I clean the coils and fan? Do I remove the cover & take a low pressure water hose to it? I reallize a pressure washer will bend the fins, in which now are good & straight.
    Problem Solver:
  • 7 Answers
Make sure the coils and fans are clean.
Unless there has been a leak in the lines this will solve your problem.
Posted on Jun 19, 2009
1500 PU DIES WAN T START WAIT 5 MIN. WILL CRANK BACK UP
Possible failed fuel pump
They wear mechanically & electrically & work
on & off for months
You could have 10 other issues & not be the fuel pump
Look at Freeze Frame Data when it quits
Jul 26, 2014 | 2001 Dodge Ram 1500 Truck 2WD
My Knemore Side By Side Model Number 253.52349302 refrigerator gets too cold, it freezes everything. Have to turn knob to almost off to get refrig to quit freezing.
Hi,There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Aug 13, 2011 | Kenmore Side by Side Refrigerator
Fridge is freezing all liquids freezer is turned down as low as possible and liquids are freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 24, 2011 | Magic Chef CTB1922 Top Freezer...
Refrigerator is freezing my produce items (veggies&fruits) Freezer side is thawing and ice is melting waterfalls over and down all other levels. Freezer & frig. settings have always been set on...
heatman101
Dec 10, 2010 | Kenmore 25.1 cu. ft. Side-By-Side...
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
In the last week i have filled the coolant reserve tank several times, total of 2 gallons of coolant, and yet the reservoir runs dry and requires more coolant. I cannot find any coolant leaking under the...
hi, if your 100% sure that their is no coolant leaking onto the floor then look inside the car where the drivers and passenger feet are if the floor is wet then this means the heater rad is leaking and needs replacing if its dry then this could be a more serious problem now what you need to do is check your oil pull the oil stick out and check for signs of water if water is present then it will look a grey color and this would mean head gasket failure if how ever the oil level is ok and the color is normal then this could indicate that the head gasket has gone and the coolant is being burned out with the engine gasses, you need to get a compression test done and possibly a sniff test to test the coolant for signs of gasses from the engine.
Let me know how you get on or if you need further assistance ok
Feb 08, 2010 | 1994 Volvo 850
I have a suburban lp furnace and duotherm air/heat pump roof unit. duothern thermostat. 20 amp breaker kicked ( reset breaker) & furnace quit. NOW furnace fan comes on but does not light, and the front...
I'm not sure what the problem may be but you could try calling All Seasons RV Appliance Parts & Service. There number is 1-800-344-0673 they have helped me in the past. That and there tech calls are free so it wouldn't hurt to give them a call.
Jan 23, 2010 | Dometic Rooftop RV Air Conditioner
Dometic/Duotherm propane furnace won't fire up
If this unit has a spark ignition you may just need to clean the flame sensor. It is a metal rod protruding in the path of the flame.
Feb 10, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
367 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
