Question about Home
Parts diagram for 1988 camaro iroc z-28 - Home
dr_layinlow
  • 60 Answers
SOURCE: starter on a 1988 camaro iroc z
go to your local auto zone or advance and get a manual and look it up!! hell jus go in with a friend and pick da book up and jus walk around like your looking and read up on it!! I would have to check others but im sure i people that know!! Let me know if you are unable to do this!
Posted on Dec 07, 2008
cobrasdh
  • 39 Answers
SOURCE: restoring 1990 camaro iroc-z convertible
thirdgen.org has a wonderfull classified section
Posted on Mar 26, 2009
  • 6982 Answers
SOURCE: 88 camaro poor idle when engine is warm
Don't remember if they used an idle air control valve or mass air flow sensor on ones that old but either can do that. If not check your vacuum hoses for splits, cracks and good connections. You did not list engine size, but controls are pretty much the same. I'm pretty sure you can do a computer scan on those by jumping the under-dash connector...get a manual for codes and instructions on that.
good luck!
Posted on May 23, 2009
  • 3 Answers
SOURCE: 1988 Chevy Camaro Iroc Z
The engine fan switch is located in the right side cylinder head between the spark plugs. There are two different sizes that you might find installed, 5/16 or 9/16 inch threads.
Posted on Sep 02, 2009
  • 484 Answers
SOURCE: do you have a spark plug wiring diagram for a 1988
Okay, #1 is marked on the distributor so in clockwise order: 1-8-4-3-6-5-7-2
8 7
6 5
4 3
2 1
(Front)
Hope this helps,
matt
Posted on Oct 07, 2009
Where is the horn relay located on a 1988 camaro?
I believe it is plugged into interior fuse box.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://ca.answers.yahoo.com/question/index?qid=20080504172413AA78RKW
Fuse box diagram for 1988 Camaro Iroc
1988 camaro fuse box location Google Search
Mar 19, 2016 | Cars & Trucks
How do i replace the rear axel bearings on a 1988 Chevrolet IROC Z28 Camaro
Put car in neutral, remove wheels, calipers and rotors, diff. cover. rotate carrier until you see wrist pin retaining bolt, remove bolt and slide out the wrist pin out of carrier. Next push axle inward to remove inner axle "C" retainer washer then slide axle out of tube. Then pry off axle seal and with slide hammer w/attachment remove axle bearing.
Feb 23, 2014 | 1988 Chevrolet Camaro
1988 CAMARO IROC BELT DIAGRAM
there is usually a belt diagram on the fender well close to the belts..or check with parts store for your model..
Dec 16, 2013 | Cars & Trucks
Where is the location of the temp sending unit in a 1988 camaro iroc z
On the thermostat housing. Please rate me on this answer.
Jun 11, 2010 | 1989 Chevrolet Camaro
Do you have a spark plug wiring diagram for a 1988 camaro iroc z 305 tpi
8 7
6 5
4 3
2 1
(Front)
Hope this helps,
matt
Oct 07, 2009 | 1988 Chevrolet Camaro
Starter on a 1988 camaro iroc z
Sep 27, 2008 | 1988 Chevrolet Camaro
Vacuum hose came off from somewhere
some cars have a vacium diagram tag some where under the engine compartment but if not go to autozone.com and try to get the diagram, or try to add pictures here so i know what are you refering to
Jun 15, 2008 | 1988 Chevrolet Camaro
Home Logo
63 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
