Question about Singer Quantum XL-1000 Computerized Sewing Machine
Calibrate brother embroidery machine
Need to calibrate screen
  • Singer Master
  • 1,388 Answers
MY lights come on but the LCD screen is blank and it is beeping. Please help
Check that the LCD screen adjustment has not been dimmed or darkened. If that is not the case, then a component is or has most likely failed.
Dec 30, 2015 | Brother Sewing Machines
How do i do a screen calibration on a PC-8500 sewing/embroidery machine?
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
Nov 18, 2014 | Brother PC-8500 Pacesetter Embroidery &...
Pc-8500 how to calibrate touch screen
ADJUSTMENT
match.
Brother embroidery machine
Please contact your brother embroidery machine provider. Or you ask experience Brother embroidery machine designers.
Feb 16, 2014 | Brother Sewing Machines
Need embroidery foot for Brothers Ult2001
Most sewing machine stores that have Brother machines will probably have the embroidery foot. Ask for part XA5500-001. It's available online here for $22: http://www.sewingpartsonline.com/screw-in-embroidery-foot-brother-xa5500001.aspx . Amazon.com also has the embroidery foot: http://www.amazon.com/Screw-Embroidery-Foot-XA5500001-Brother/dp/B0038RAVXI .
I hope this helps.
Feb 20, 2013 | Brother ULT2001
My brother embroidery machine's lcd screen is blank
Hi.
On page 81 of your manual it says to adjust your LCD screen brightness.
If you can't find your manual... go here and download it.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_PE_770%20%20%E2%80%93%20New!_EN_1819.PDF
Jul 13, 2012 | Brother Sewing Machines
Recently during an embroidery the needle started "fixing" very rapidly and wouldn't stop. Had to unplug it. Now designs will load to the point where I touch them choose the one I want. The...
Make sure the embroidery unit is plugged in securely. If it is only a tiny bit out of its socket, the machine will behave erratically. Also ALWAYS "park" the embroidery arm before removing it by pressing the Needle Down button. Do this before you turn the power off when you are done embroidering. If the arm is not in the correct position when you plug it in (i.e. has NOT been parked) then it won't calibrate properly. I believe you can manually move the arm into the parked position. It's not something I would want to do myself but if you are really stuck it might be worth trying. You need to exert quite a bit of force. Also be sure to remove any hoops before you "park" and remove the embroidery unit.
Can you access the Menus properly when the embroidery unit is not on the machine? If you can, recalibrate the touch screen by going to the Set menu, scrolling through the "More" pages until you find "Calibrate Touch Screen Adjust". Use your stylus or the blunt end of a machine needle to touch exactly in the centre of the crosses, starting at No.1. It will turn green then do No.2 and exit the screen (OK) without touching anything else.
If you can make the machine work, try doing a different embroidery - there may be a problem with that particular one. If you cannot get it to work properly, it will need to be seen by a repair technician, sorry.
Jan 16, 2011 | Husqvarna Designer I
Brother 4000D does not sew out patterns correctly and sometimes jams.The designs are sewn with parts missing or in wrong position. I have tried the same patterns on my Pfaff and no problems but my 4000D...
Try sewing instead of the embroidery feature.
If the stitching is messy, the machine needs to go into the shop for service by an authorized Brother dealer as the timing needs to be adjusted. Take a sample of the problem with you.
Apr 03, 2010 | Brother Disney PE-400D Computerized Sewing...
Singer Quantum XL-1000 Computerized Sewing Machine Logo
51 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
