Question about Echo CS400 18" Chain Saw
Chain flys off every 10minutes
Most of the time, when the chain flys off,it destroys the chain.
    Problem Solver:
  • 11 Answers
Check to see if the bar is bent [straight edge]. is the sprocket in good condition. Buy a good quality chain & keep it tight always
Posted on Jul 23, 2014
At what mileage must the timing chain/belt be replaced?
Now a days, timing chains are usually good for the life of the engine. However, timing belts are usually recommended between 60,000 and 100,000 miles.
It will be good to know if your engine is "interfering" or "non-interfering".
That means, if the belt breaks, will it destroy the engine (interfering) or not (non-interfering).
God bless your efforts.
Oct 02, 2015 | 2006 Ford Bantam 1.3i
How to fix sorento timing chain noise, i have replace the timing chain but still have not fix the problem.
Those KIA are dropping like flys on here,
the last week or so
The repair shop should have bulletins in their
data base & experience with that
Need to find those things out before you buy
Sorry - I never knew until last week
Kias had all the problems they do
Try Googling the question
Try You Tube Video
Try KAI Blogs
I have an 04 lincoln with many more chains than you
do & no prolbems
I think all that is caused by going too long
with oil changes & not knowing what oil has
been installed
Mar 11, 2013 | 2006 Kia Sorento
Engine overheats
bettr git that timing chain replaced before u destroy the engine--if it breaks it bends the valves--inspect front seal etc also
Sep 05, 2012 | 2003 Chevrolet Cavalier
What are the symptoms of a timing chain problem? How difiicult is it to replace if I wanted to do it myself?
when the chain got older it got loose due to the tensions so it will make your car`s engine sounds louder but if the chain cut your engine will be dead and in some engines the piston will hit the valve destroy each other so don`t underestimate that timing chain it is really critical
it is had for you to replace it cuz you could miss the timing settings go to shop
May 23, 2011 | Chevrolet Avalanche Cars & Trucks
Cannot keep chain on bar and ruins chain when it flys off 455 rancher. i have used chainsaws for 30 years w/o this problem
I would guess that you have already checked this but many years ago I got ahold of a bar for my stihl .029 super farm boss that had a slight warp in it. It would work fine at most r.p.m.'s but when you ran it wide open it would toss the chain. It took me awhile to find this and on mine if you wern't watching very close you would never see it. I hope this helps you some, Good luck and thanks
Nov 20, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
On the 2004 Element. Do you have to change the timing belt at a particular time ; or does it have a Chain?
Honda element has a Timing Chain, and Honda doesn't even recommending looking at it till something like 110,000 or 120,000 miles.
However, it is this an "interference" engine, meaning that if the chain or belt fails it could destroy the valve train and even the pistons.
Because it is an interference engine. I plan to change my chain at 100K, since I expect the car to go at least 200K but don't expect the chain to last that long.
Normally cars has Tune ups scheduled at 30K, 60, and 90K. As the rule of the thumb at 90K Tune up mechanic shops recommend timing Belt or Chain to be replaced. We can go for longer taking the risk.
Oct 23, 2010 | 2004 Honda Element
When is a normal time to adjust the timing chain and is it necessary if you have never had any problems
your book will say the service interval for the chain. It called a belt. Its usually done around 80,000. No adjustment can be made. It gets replaced. If you fail to replace it it can break and destroy the engine.
Nov 09, 2009 | 2001 Hyundai Elantra
2000 ford 4.0 sohc how to set feront timing chains chain stops broke off now cannot reset no timing marks
you kinda destroyed it. you need specialty tools, a good manual, and new parts. You don't do this right the first time, you bend valves, period.
Oct 27, 2009 | 2000 Ford Explorer
Has a 2004-2006 honda accord 2.2 diesel, timing belt or chain?
Belt is better replace either about every 100.000 or you'll destroy the engine when it goes out
Belt is Better because it's easier to replace, therefore much cheaper
Chain is inside and in the oil bath so harder= more expensive
By the way. dealer says replace every 60K . 100K is a MAXIMUM
Sep 13, 2009 | 2005 Honda Accord
Where to put the timing marks on a 96' nissan 2.4 liter
the timing chain tensioner is hydraulic and either out of adjustment or defective.  You need to remove the timing chain cover and reset the mechanical correlation between the crankshaft and the camshafts.  also the other ignition time marks are on the crankshaft harmonic balancer and the cam cover.  Do not crank the engine with the timing out of sequence or you'll destroy the engine.
Dec 26, 2008 | 1985 Nissan 300ZX
Echo CS400 18" Chain Saw Logo
64 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
colesmowers
Phil Walker
Phil Walker
Are you an Echo Garden Expert? Answer questions, earn points and help others
