Question about Bosch Dishwashers
Bosch Dishwasher showing code cl - Bosch Dishwashers
2 Suggested Answers
SOURCE: Frigidaire Dishw. Error code CL
this just happened to ours and it turned out to be the gasket that seals the door.
when you see the CL error and the door is indeed shut, pull gently back on the door. if you hear a click and the unit starts running again, it may be the gasket.
ours lost it's ability to keep the seal, allowing enough 'play' in the locking mechanism for it to think the door was not closed.
Posted on Sep 09, 2008
The display is showing alternating between CL and 0. What should I do?
How To: activate and de-activate child lock on your bosch ...
? 1:20
www.youtube.com/watch?v=lTXcTpalob4
Dec 24, 2012 - Uploaded by whichwasher2007 ... activate and de-activate child lock on the bosch logixxwashing machine range. ... you can turn the dial to '0', and thechild lock is still on, when your kid messes ... How to Identify anError Code on a Bosch Washing Machine ...
Oct 03, 2015 | Washing Machines
Dishwasher goes through cycle but when finished it is cold and code E..09 appears
Bosch Dishwasher Troubleshooting ' Dr. Dishwasher
www.drdishwasher.com/troubleshooting/manufacturer/bosch/
Your Bosch dishwasher can run a test cycle which will quickly go through each ... You can find a list of Bosch dishwasher error codes and their definitions here.
Jul 26, 2015 | Bosch Dishwashers
Dish washer goes through cycle but when finished cold with Code E..09
I have a Frigidaire dishwasher it is showing a code cl which means its not closed. I just replaced the latch with a bran new one and still is reading the code. any suggestions
Good Afternoon friend, I appreciate your post!
From what you have described your Frigidaire dishwasher is displaying an error code of "CL" and you have replaced the latch. Since the latch has been replaced it could be a problem with the wiring harness or main control. I would recommend having a professional out to perform a diagnosis and this will help you to avoid any unnecessary part purchases. Best of luck! -Matt
Mar 10, 2015 | Frigidaire Dishwashers
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
Jun 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
I have a shu43co2uc bosch dishwasher that fails self test and displays CL on display. I believe this is a bad ntc sensor. the tub has water in it an inch or two and it does get hot but pump runs a few
If the owner's manual does not give an explanation of the error code is, in the troubleshooting guide, you'll need a service / repair manual. Perhaps calling around to a few local appliance parts and repair shops- someone can clue you in on what the problem is and how to repair it.
Nov 30, 2013 | Bosch 23 in. SHU303 Built-in Dishwasher
Bosch dishwasher error code c1
Hi
Pump-out not accomplished in normal time.
Check the drainage and replace or reposition the drain hose,Clean it out by running the disposer.
Feb 27, 2012 | Bosch Dishwashers
Frigidaire pld3460rdc1 the dishwasher flashed CL when the door is closed.
The CL is letting you know that the door was closed. If it continues to show CL it means you need to close and latch before the cycle will run. If it just flashes your okay.
Mar 10, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Mar 14, 2008 | Dishwashers
Dishwashers Logo
21 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
