Question about Radio Communications
Case cx 80 clutch - Radio Communications
Yellow light on overhead panel comes on and compressor quits. turn switch off and it resets but soon cuts off again,
check for condenser fan operation or blocked condenser not allowing air flow to cool the gas
could be a blocked TX valve so have an accredited ac specialist check the gas pressures in the system
May 06, 2017 | Cars & Trucks
1980 Honda CX 500 A clutch hard to pull in
Hi, Rich you may need to lubricate the inside of the cable or replace it for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Heavy clutch
Clutch lever is too strong GL1100
Honda CX500 Shop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CX500 CUSTOM Owner Manual
Aug 02, 2013 | 1980 Honda CX 500 A
1980 Honda CX 500 A clutch torque specs
Hi, Jon for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Clutch torque specs
CX500 Torque Values and Thread Sizes
Honda CX500 Service Manual right click the chapter you want and save as
https://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-cx-owners-manuals
Feb 12, 2013 | 1980 Honda CX 500 A
How to bleed brakes on a Case CX 80
bleeder nipples will be at the top of the brake cylinders or calipers . Same as cars
Jan 02, 2012 | Milwaukee Tool Case Heat Gun
How to move CX 650 with broken clutch cable stuck in first gear
Either the tiny shift spring under the rear cover is broken or the shift linkage gear next to it is out of position. If this is the case there is no way to put the bike in neutral without removing the engine and taking off the rear cover to fix the shift linkage ( first gear lock up can happen if the shift gear pops out of place during reassembly. Always check your shifter is working correctly before bolting down the rear cover.).
If your only problem was a broken clutch cable you could shift the bike to neutral with the motor off and push it around on it's wheels. If the problem is inside the motor and it has to be moved right away put a furniture dolly under the rear wheel and keep a block of wood handy to place under the side stand to park the bike until it can be taken off the dolly.
Jan 03, 2011 | 1983 Honda CX 500 B
Have a 1982 cx-500c I'm getting a noise that kind of sounds like pins rattling around in the main fuse area. Also pulling in cluch and I think it is gone.
All Honda clutches rattle when you idle.Pull in the clutch lever and it will go away. I have owned a dozen different Honda's (100,000 mile on one CX500D alone) and the clutches all rattled at idle. All of them. Get used to it , I am afraid there is little that can be done about it.
Oct 16, 2010 | 1982 Honda CX 500 B
Loss of top end power/cant cruise a highway speeds
Your ignition timing is probably retarded and/or the clutch slips badly. I bet it runs hot too. Worst case scenario: the camshaft timing is off too.
Apr 10, 2010 | 1979 Honda CX 500 B
I dropped my 82 CX 500 and snapped off the gear shift spindle - not just the shift lever but the shaft which the gear shift is attached. Any suggestions?
The shaft is pretty easy to replace. Just remove the right side casing and then the clutch and then the shaft is pretty much ready to pull out the right side. The shaft can sometimes get bent on a fall. cut the shaft nearly flush with the casing if it is bent. The bigger problem you will likely face is a bent shift fork or two. That would require pulling the engine and splitting the center case to replace the forks. Unfortunately the chances that a fork or two has'nt been bent are pretty slim. The bike will not shift properly with bent forks.
Nov 27, 2009 | 1983 Honda CX 500 B
I have a 1998 ford escort cx wagon, the clutch has broke..is it possible it could be the cable? does it have a cable? or is it a hydraulic clutch? or would I need to replace the clutch? :-)
Hi!
There may be a possibility the cable has snapped, however Ford used a ratchet and pawl set up on the Escort which is made of plastic! when it reaches its full tension (Self Adjusting) it can break leaving you with a baggy soppy floppy clutch pedal. So a clutch replacement is NOT required!
If the cable has broken you should be able to see from under the Bonnet/hood as it is situated on top of the gearbox Bell housing. Again a Clutch is NOT needed.
Hope this sorts it?
Press the Blue Button please to appraise my FREE! Effort.
Thank You!
Paul 'W' U.K.
Mar 02, 2009 | 1998 Ford Escort
Location of the fuse box in the case cx 90
petterson_92 was right there is no fuse box in the PC Case, if you wanna find the fuse it inside the Power supply.
Dec 21, 2008 | Computers & Internet
Radio Communications Logo
24 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
