Question about Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk
Nutool tile cutter motor - Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk
SCREW THAT HOLDS BLADE ON TILE CUTTER MODLE#3210N
You mean the bolt that holds the blade on im sure. It's not a screw. lol. Those you can get at any tile willcall place where they have a tool counter and try Home Depot.
Oct 06, 2014 | Saws
Why does tile veer off?
If you have a bridge saw. The blade and motor may not be parallel with the rails the motor travels on.
Feb 18, 2014 | Felker FRS-38 Tile, Marble & Granite Rail...
What is a wet saw? is it easier to use than a tile cutter?
Wet saws make cutting thick or strong tiles easier, they also make it easier to make multiple cuts on a tile. It takes longer to use the wet stone so if you don't really have to use it then cutting with a tile cutter will go much faster.
Nov 17, 2013 | Cutter Tools
Do I need a lot of tools to cut tiles?
You don't really need too many tools to cut tiles, mainly just a tile cutter, tile nipper, sharpening stone and pencil.
Need manual for crain Model A tile cutter
If you go to the Crain website http://www.craintools.com/fs-more_pages/fs-001.html it gives a good description of the tile cutter and shows how the self-measuring feature works and includes a parts list but they don't have a downloadable manual.
Jan 21, 2012 | Saws
I just bought a Kobalt 20" tile cutter- it came with no user's manual. where can I download one?
Hello, go to Lowe's hardware store. They handle Kobalt tools. I wish you luck. GB...stewbison
Sep 22, 2011 | Heavy Duty Kobalt Tile Cutter In Box 20 "...
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Was cutting tile and it just shut off. Blade seemed dull. Does blade stop running when it needs to be replaced?
no it does not there is a fault with the cutter arm in most cases its a broken switch or its brusges are too worn
let me know if you need more advice
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Ridgid Wts2000l 10" Wet Tile/stone Saw Cash Saver Lk Logo
41 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
