Question about Stihl Blower Bg72 Hand Exhaust Muffler Gasket Bg 72
Where go the ground cable in the stihl bg 72 - Stihl Blower Bg72 Hand Exhaust Muffler Gasket Bg 72
It connects to the metal body via a small lug spade type connector
usualy this ground wire is used to by the switch to turn it off
Posted on Dec 04, 2014
2 Suggested Answers
  • 311 Answers
SOURCE: Parts for a stihl bg 72 carburetor
Make your own.
Pull carb,use thin paperboard,punch 2 holes for carb mount and place on carb,lightly tap on carb throat to make an outline of where you need to make big hole.
I use steel tubing and punch small holes over a block off wood.
The big hole a a bit tougher to make perfect.
Posted on Nov 18, 2012
STIHL BLOWERS BG 56/C and BG 86/C
I don't have much experience with Stihl products but I do have a couple of disc cutters, both of which had a short life and suffered piston damage.
I suspect the air cleaner isn't as efficient as it should be.
Apr 26, 2017 | Stihl Garden
Stihl BG 72 blower starts and idles fine, but when I give it more gas its power and speed variate. Will not maintain steady speed.
Did you check the seal between the carburettor manifold and the cylinder? Could also be a fuel starvation problem, fuel tap, pinched lines, stuck carb float.
Nov 06, 2015 | Garden
Leaf blower spark plug gap
Hi
Recommend 0.025 inch (25 thou) or 0.6 mm.
Regards
Jacko from down under.
Aug 13, 2014 | Stihl Bg72, Bg 72 Handheld Blower Exhaust...
Download still sh55
http://www.h-machine.jp/part_list/stihl/stihl_BG%2045,%20BG%2046,%20BG%2055,%20BG%2065,%20BG%2085.pdf
Illustrated parts list of BG 45, BG 46, BG 55, SH 55, BG 65, BG 85
including the breakdown of the C1-s50 and C1-s55 carbs
Mar 10, 2013 | Stihl / Zama Blower Carburetor Bg 45 46...
Make your own.
Nov 16, 2012 | Stihl Bg72 Leaf Blower Intake
Air and mixture screws setting hs61
Standard Carb settings on Stihl equipment are H 3/4 turn out anticlockwise from full screwed in position. L 1 full turn out anticlockwise from full screwed in position. :)
Nov 02, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Stihl 250 chain saw will not pick up speed
Is the chainbrake in the 'off' position.? Pull the black hand guard back to release the 'chain brake'.
Oct 16, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Why my stihl fs 250 not accelerate
Have you removed the chain brake.? Pull back the front 'black' hand guard to release the chain brake.
Jul 21, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Why does my Stihl BG 86 Leaf Blower not accelerate?
remove the muffler and run it if ok open the muffler and clean the screen in side they build up with carbon and stop exhaust flow
Jun 15, 2012 | Stihl Bg Fr Hs 60 61 65 72 74 76 80 81 86...
Stihl Blower Bg72 Hand Exhaust Muffler Gasket Bg 72 Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
