Question about Refrigerators
Water leaking from the hinged side of the freezer door at the bottom. Not continous, seems to be tied in with the defrost cycle. Ice forming in bottom of freezer. Model # MSD2754GR
  • tro4818 Jun 19, 2009
    Did as you suggested. There was ice on the bottom but no hole! There is a large hole on the side wall that I believe goes to the veg draw. The shelf in the back has a grill where the fan is but I can see nothing else.
  • 82 Answers
If you open the freezer door and remove the bottom basket, there will be a small shelf with a hole in it, if it is covered with ice the drain is most likely plugged. hopefully you can remove the ice with a hair dryer and run some hot water down and clear it. If not you may have to go in from the back and remove the drain tube. this is a serious pain in the ***.
Posted on Jun 19, 2009
My fridge is leaking, water drips out once day from the left side where freezer side is.
Not sure what model you have or the age, but it could be the door gasket. It could also be the door closure at the bottom of the hinge side being worn down and not closing the door all the way. These normally last about 15 years.
Nov 02, 2017 | Refrigerators
Water leaking from under the freezer
Until defrosting the block of ice you canot see if is a hole or crack in the bottom. But I suppose is leaking from the door gasket under the pressure of the ice inside. Anyway, if you want to keep alife your refrigerator, better unplug it, defrosting and clean it before complete annihilation.
Sep 10, 2017 | Frigidaire Refrigerators
Water leaking from inside the freezer
if the bottome of the freezer floor is frozen then the most common cause is that the defrost drain is cloged, the back wall will mostlikley need to be removed and defrosted, then i use hot water & a long zip tie to make sure the drain is clear, don't use anything too hard as to punch a hole in a drain hose.
May 24, 2010 | Samsung RS2630SH Side by Side Refrigerator
Lots of ice & water on the floor too
I would check if the cooling coils and drain in the freezer are frozen. Thaw this ice, especially the ice in the drain. If it happens again within a few days, you need to investigate the defrosting circuit.
Oct 04, 2009 | LG Refrigerators
Door doesn't close properly, leaks water
If the door seals are still pliable and intact there are two possible causes.
1/ The upper door hinge on the top of freezer unit has two adjusting screws under a plastic cover/cap which allows the upper hinge to be set forward or back altering/adjusting the spacing of the door seal to the freezer body. Moving the hinge outward at the top will cause the door to seal tighter at the bottom and lessen escaping cold air and condensation to form (water droplets). Adjust carefully so as not to create a weak seal (air gap) along other sealing edges of the door frame.
2/ Many United Refrigeration Commercial Freezers are manual defrosting. Moisture from inside the freezer can condense between the inner molded door panel (door shelves) and the exterior metal door. Usually ice buildup will occur in this space, but when defrosting or during high ambient temps the ice will melt and drip out along the bottom door edge/seal. Screws alomg the door frame (hidden by the door seal) hold the seal in place and also the inner molded door panel. The inner panel can be removed to replace the seal or to remove the ice buildup.
Jun 04, 2009 | Freezers
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Water leaking and ice in bottom shelf of freezer
Chances are you have a bad seal around the door if it's leaking from the inside which causes the ice to form as well, or if it's leaking from under the freezer you lave a bad heating element that evaporates the water collected in the pan under the freezer or you have a clogged hose that goes to the pan under the freezer which also causes the ice to form because the water has no place to go. Defrost and try to find a way to blow out the hose that goes from your freezer to the pan under the freezer and that should take care of your problem.
Apr 18, 2009 | Refrigerators
Ice forming bottom of freezer leaking out the door
It is acutually a collector pan for the drain hose. When the refrigerator runs a defrost cycle (about every couple days), that pan collects the water from the ice that is melted and drains it through a hose inside the unit, to a pan under the unit. You will have to pull the back panel off the back of the freezer and melt it with either hot water or a hot blowdryer. Do it until you see the water draining freely into the bottom pan.
Oct 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
GE frig just starting leaking water at the bottom of the freezer side door
more than likely you have a frozen defrost drain look in the bottom of your freezer section there should be a depression there see if its just a big block of ice let me know if this is the case or not and ill tell you how to clear the drain if not then we will look at something else please dont rate me till were done
Jan 11, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
172 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
