Question about KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
F2 code for kitchen aid front load washer
Every load i wash the machien (kitchen aid front load washer 3 years old) stops and displays a f2 code what does this mean
  • 3 Answers
SOURCE: Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Posted on Dec 29, 2007
Coldcut
  • 1554 Answers
SOURCE: kitchen aide khws02rmt0 washer
random issues with bad solder joints on the boards ,
open the top of unit , reseat all the connectors on the control unit.
start washer ,
, push up gently on the center black wired connectors . system should start and run fine as long as you hold it up. normal issue is that the solder connections to the relays need to be resoldered due to crack around the leads.causing random issues
german manufacture board
Posted on Mar 26, 2008
ngfam1
  • 639 Answers
SOURCE: kitchen aid top loader washing machine does not spin
Peace Friend,
ngfam1 At your service!
Sounds like a belt problem!
Or the linkage connecting the transmission to the agitator.
Or the WORST THE TRANSMISSION IS GOING!
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
Posted on Aug 31, 2008
SOURCE: kitchen aid washer
Hi , washer is not spinning . found motor coupler had broken . need help on the best way to replace .
Posted on Oct 15, 2008
allbrands
  • 600 Answers
SOURCE: I'm getting an F2 code on my Kitchaide front load
F2 on this unit is long drain. Take the front lower cover off (3 screws on the bottom) and you will see a round white cover about 4 inches round. That is the pump clean out. Before you twist that cap off be aware the water will come out have some towels ready. Take the cap off and you will see all the junk in there remove it and replace the cap. Thats it good luck..
Posted on Jun 06, 2011
F2 Code???
Probably blockage in pump or sump
Jun 17, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Code F11 appears about 10 minutes into cycle or at the end when the door should open. Kitchen aid front load washer six years old
Hi
F11 is a motor control unit error which means that the motor control unit has repeating under or over voltage or over current conditions due to internal failure. You can check the wire harness connections between the motor and the MCU (motor control unit) and also between the central control unit & MCU. If the motor is working then replace the motor control unit. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
No instructional manuals.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182140.pdf
will take you to the washer manual and
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182400.pdf
is for the dryer.
Apr 20, 2010 | KitchenAid KHWS01PMT Front Load Washer
Washing machiene drum won't turn
it sounds like you've got an item of clothing jammed between the inner and outer drum
Jun 22, 2009 | Indesit W 123 Front Load Washer
Kitchen aide front loader washing machine won't finish cycle
On ours, i think that those codes were overload codes.. i had to go downstairs and turn the circuit breaker right off for about 5mins - when i clicked it back on, the washer reset.. i took some of the extra wet towels out and ran another wash with no issues..
good luck
tpug
Apr 27, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Loads interrupted
interrupted wash cycles and also give a code of F06. A service tech was supposed to be at my residence today... he did NOT show. This machine is little over a year old. Tried unplugging with no sucess. Any help would be appreciated.
Sep 15, 2008 | Kenmore Elite 45986 Front Load Washer
Washing machine
check pressure switch hose
Jan 02, 2008 | KitchenAid KAWS850L Top Load Washer
Washing Machines Logo
365 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
