Question about Kenmore HE5 Electric Dryer
The door doesn't seem to be engaging the sensor to let the dryer know that the door is closed. If I push on a certain spot on the door, it will turn on but it stops soon after I release. It seems like the door is a little loose on top. how do I tighten it or do you have any other suggestions?
  • 999 Answers
Look closely at the latch on the door. it could be the door is slightly twisted. Grab the bottom of the door with one hand and pull towards you as you push forwards on the top of the door. If it is ok and the switch inside the frame is not loose you are going to have to replace the switch
Posted on Jun 19, 2009
Dryer doesnt stop when I open the door
Switch for the door is sticking or bad. It is usually the same switch that turns the light on when the door is opened. I just checked mine, it was sticking a little. I pushed it in as far as possible and sprayed a tiny amount of WD-40. Pushed in and out several times. No more stick. A very light oil might work also. Otherwise you have a bad switch.
Feb 28, 2015 | Washing Machines
How many sensors to test dryer door switch, one or two?
the female is the switch! you can pop the top off and check with electric tester on ohms, make sure you unplug the drye
check the breaker make sure you have 220 volts a in the outlet !
Aug 15, 2017 | Maytag Neptune MDE5500AY Electric Dryer
Westinghouse Electric Dryer, Drum doesn't turn on start up, if your spin drum and close door it will start,
Either something is binding the blower wheel up or the motor is bad. The best thing is to take the front of the machine off to access the blower wheel to verify ifanything is indeed binding it.IF not read the next section.
If you can turn the drum and then the dryer starts you have a bad motor. The way the dryer works is when you initially push the start button, electricity is sent to the start winding, or stator, of the motor. This will in turn start the motor turning. From there the stator will drop out of the electrical process and at the same time the run winding, or rotor, will take over and the motor will continie to run. Your stator is damaged, has a burn spot, etc so by you turning the drum, the belt around the drum is moved which is attached to the motor pulley. You basically take the place of the stator. Long story short, you have a bad motor.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 22, 2012 | Westinghouse Laundry Dryer Motor...
I have a kenmore elite dryer hE4. the dryer will run for a while then shut off... and will not restart for a while, i have changed the moisture sensor, thermistor, thermal fuse, the moisture sensor wire...
its a door switch problem. Make sure the door is latching properly at the top. If the top latch doesn't engage properly the door switch won't make contact.
Try holding the door switch closed with your finger and starting the dryer. If it still wont start and you have no error codes displaying you will most likely have to replace the switch. if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks Rick
Apr 13, 2011 | Dryers
Will not turn on
1. Not plugged in
2. Circuit breaker open
3. Damaged cord
4. Bad switch
5. But most likely the "closed door sensor" is not engaged. Look for something that goes through a hole when closing the door. Check its alignment and stick something in there to engage the sensor, or replace it.
Jul 31, 2009 | Dryers
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Apr 30, 2009 | Whirlpool WED9500T Electric Dryer
Dryer won't start.
there should be a push in switch that the door pushes against
Apr 23, 2009 | Dryers
Whirl pool dryer LEC9000PW0 will not turn on
Has a household fuse blown or has a circuit breaker tripped?
There may be 2 household fuses or circuit breakers for the dryer. Make sure both fuses are intact and tight, or that both circuit breakers have not tripped. Replace the fuse(s) or reset the circuit breaker(s). If the problem continues, call an electrician.
Is the correct power supply available? (Electric dryers only)
Electric dryers require 240-volt power supply. Check with a qualified electrician.
Is the dryer door firmly closed?
Your dryer door may not be fully closed. It may look shut, but may not be latched. Push on the door to engage the latch or latches. Some models have an upper and lower latch. Both latches must be secure for the dryer to run.
Was the Start, Push to Start or Hold to Start button firmly pressed?
Large loads may require the Start, Push to Start, or Hold to Start button to be pressed and held for two to five seconds.
Is the Cycle Control knob set on a Sensor Dry or Timed Dry cycle? (on some models)
The Cycle Control knob must be set in a Automatic Dry or AccudryTM or Timed Dry cycle. The dryer will not start if set on the Wrinkle ShieldTM option.
Is Controls Locked status light on? (on some models)
Press and hold the Cycle Signal button for three seconds. This will turn off the Controls Locked feature.
Did you recently install a power supply cord on the dryer? (Electric dryers only)
The power supply cord may be incorrectly installed. If the power cord is incorrectly installed, the dryer may not start or heat. Review the Installation Instructions to check that the power supply cord is properly installed.
Dec 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Won't work at all,
Hi Lanil,
The only things that will not allow the dryer to start are the following:
  1. I know you said you checked the breakers, but they could be the cause.
  2. The Child bouncing on the doorcould have broken the stub stub that pushes the door switch in.
  3. You may need to firmly press the Start switch.
  4. The dryer need to be plugged in, I know you checked it.
These are the four main things. Since the child bounced on the door, the trouble is most likely with the door switch. Try to use a stick or something to simulate the door closing and activate the switch and push the start button. If this starts the Dryer, and closing the door firmly does not, then the switches position or doors prod that pokes the switch, is not lined up or failiing to fully activate the door switch.
Nov 02, 2007 | Whirlpool LER5636P Electric Dryer
Kenmore HE5 Electric Dryer Logo
209 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
