Question about Acer Aspire L100 PC Desktop
The Acer Aspire L100 System powers on but there is no display.
I tried the suggestions in the first solution, but that did not work for me. Is this something that is fixable or do I need to buy another motherboard or PC?
  • Frank Zabroski
    Frank Zabroski May 11, 2010
    Please explain the problem in full detail so we may help you. Do not repost it as a new problem. We have no way to go tracking that information down.
    Scholar:
  • 155 Answers
Open the case and try to take out memory card and wipe it or if there is an pencil eraser beside you try to look for some dusty connection that might block the passage of signal to any device. Place it again but do not invert the proper placement of the card. If it doesn't display, try the cable wires to fix it in its place. Next, try to take out cables from HDD and place it again to its proper place where you got it.
Posted on Jun 19, 2009
I reset my surge protector and the computer wont power up. i think i need a new power supply. the power cord is working fine. Please let me know where i can find a power supply for the aspire...
The Acer Aspire L100 is a desktop computer powered by a special DC adapter and power cable. The computer's motherboard incorporates a fuse designed to prevent any power surges from damaging the computer. If the fuse burns out due to a power surge or for any other reason, the computer will no longer function. You can check the motherboard fuse for damage yourself, then take it to a trained technician for replacement if needed
Shut down the Acer Aspire L100 and turn the tower around.
Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
Unplug the power cord from the rear of the tower
Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack
Let me know if this helped..
  • 2 Press the "On/Off" button on the front of the tower. If the computer will not boot and the fan does not turn on, the fuse may be burned out.
  • 3 Unplug the power cord from the rear of the tower.
  • 4 Turn the tower on its side and remove the Phillips-head screws connecting the back panel to the Aspire L100's cabinet.
  • 5 Pull out the motherboard assembly gently from the back of the cabinet. The internal fuse is located on the motherboard behind the DC power jack, which is to the right of the monitor jack.
  • Read more: Fuse Location on Acer Aspire L100 ' eHow.co.uk http://www.ehow.co.uk/how_7815704_fuse-location-acer-aspire-l100.html#ixzz1XUVwmxuA
    Sep 09, 2011 | Acer Aspire L100 PC Desktop
    Why, when i try to install driver for vga card in a acer aspire L100 computer, the sistem is shuting down?
    Hi
    thank you for your query
    Please can you try the following
    1) go to www.devicedoctor.com
    2) Download and install the device doctor software
    3) Once installed open it up and click scan, it will then scan your PC for the best driver
    4) Download the driver (entitled VGA driver) and install
    5) Restart and see if this cured the issue
    Regards
    Shauqat
    Jun 02, 2010 | Acer Aspire L100 PC Desktop
    My Acer Aspire L100 doesnt start. Only the fan works but not the system. I had this problem for 2 years but when i switched off the button and then on again after some tries it worked but now even the ON...
    ok, try to locate the battery on the mother board, before that make sure the main power cable is unpluged.
    remove the battery , and then remove your ram carefully, wait for 10 minuts, the replug every thing, and dnt forget the power cable :)
    it should work.....if not, replug everu thing again and plus the vga...
    May 11, 2010 | Acer Aspire L100 PC Desktop
    We are getting a No Signal on our monitor,
    it should be motherboard problem.
    try to check it nearby service centers
    are you able to hear any beep sounds
    pp
    Nov 21, 2009 | Acer Aspire L100 PC Desktop
    Where is the power on button on the acer l100
    moz-screenshot.jpgdear,
    if you have manual see in it on page 27/51 and if you dont have then here is the manual for you, see this page and u will see that the power button is on the front side at a corner...
    http://safemanuals.com/user-guide-instructions-owner-manual/ACER/ASPIRE-L100-_E
    click on pdf file named "Download the complet user guide" and after click that there a new small window will open and ask you to type code that is being displayed on the left side one by one...
    goodluck...
    surely, it will fix your issue so dont forget to rate it...
    Aug 31, 2009 | Acer Aspire L100 PC Desktop
    Power but no display acer aspire L100
    Try these sequence(you need another one good computer to test and interchange component and you will find out the problem):
    - check your RAM, if you use two RAM start computer using one and interchange it to find out which one is bad
    - if your RAM OK, check your VGA
    - if your RAM and VGA OK, try to check your power supply, sometimes defective PS cannot supply sufficient power to all component to work.
    hope this will help you.
    Jun 07, 2009 | Acer Aspire L100 PC Desktop
    Hello I have problem my pc acer aspire l100 i have problem power yes light yes job dvd-rw and fan cooler so no screen display monitor only black please can you help me
    Does your laptop beep at all when you turn it on?
    Try unplugging the laptop and removing the battery for 5 mins, then try again.
    If you have another monitor you can use, plug it in to your laptop and see if you can get a display on it.
    Mar 15, 2009 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 overheating
    You could try a new cpu fan and heatsink. They are normally inexpensive. if this does not work make sure all the case fans are working and check to see if your ram is overheating
    Dec 22, 2008 | Acer Aspire L100 PC Desktop
    Acer aspire sudden death my acer aspire L100 can't boot, only the noise of the fan and the DVD player. nothing else can anyone help please ?
    Dear sir
    if u don't get eny display 1 you need to cleane RAM then it's still not working you need to chek power suply.. and chek yr cables is attached is right or not.
    simple.. if u need more help please contact feel free.. thianks..
    Dec 15, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100
    http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com/au&siteid=8116&areaid=12&formid=3394#results
    just copy and paste the above link on the browser.....you will be redirected to the drivers page of acer aspire l100.....there you can download the required drivers.....try this....it will work 100%....
    Sep 21, 2008 | Acer Aspire L100 PC Desktop
    Acer Aspire L100 PC Desktop Logo
    151 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
