Question about Plantronics Explorer 340 Wireless Headset
Change battery plantronics - Plantronics Explorer 340 Wireless Headset
How can i change the ringtone for plantronics M165?
Why would you want to change the ringtone on a headset. I think they are preset from the factory
May 03, 2014 | Marque 2 Headset Plantronics Marque 2 M165...
Plantronics CS55 headset.
Greetings,
I also use a headset at work from the same company (Plantronics), If the battery is faulty it will not power and you can't use it.
The wiring has gone bad. Try re-connecting all wires.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jun 19, 2008 | Plantronics CS55 Wireless Headset
My headset will not hold the charge very long - is there a fix for this - is there a battery somewhere on this unit that can be replaced?
Unfortunately, the Plantronics Voyager 510 Bluetooth headset does not have a replaceable battery, it is "hard wired". However the 510 headset does have a one year warranty, so Plantronics will replace it within the warranty period. If it's out of warranty, you can buy a replacement if you'd like or buy the newer version which is the Plantronics Voyager Pro+, which is just a newer, slimmer model and it also has newer technology (for the same cost). Here are the links below.
Here is the link to the Plantronics 510 replacement headset.
Here is the link to the Plantronics Voyager Pro+.
Good luck from Headsets Direct!
Aug 25, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Headset stopped working. Is there a battery to change?
Unfortunately the battery is not replaceable, but you can purchase a replacement headset. Here is a link where you buy the replacement headset:
Plantronics CS70 Replacement Headset
Jul 27, 2011 | Plantronics CS70 Wireless Headset
My 330 doesn't turn on, does it require a battery? If so how do I change the battery?
If the Plantronics Explorer 330 will no longer turn on, it could be that the internal battery is worn out. The battery is not replaceable, it is internally hard wired. A current replacement headset would be the Plantronics M20. Please see link below.
Plantronics M20 Bluetooth Headset
Feb 05, 2011 | Plantronics Explorer 330 Headset
My headset quit working. It's dead - is there a battery that I should be changing?
Unfortunately the battery in the headset is not replaceable. But you can purchase a replacement headset to use with the base. Here is a link where you can buy the replacement headset:
Sep 29, 2010 | Plantronics CS70 Wireless Headset
How to Replace the Battery of 590 plantronics?
17 jun 2010
Thank you safauoc! I am going to look into the matter of replacing the battery on the now discontinued and very expensive Plantronics 590a.
753f191.jpg It came as a very big disappointment to learn that this headset is not compliant with Bluetooth V2.0 and the Blutooth Handsfree Profile. To get it to work with Skype, I had to purchase the Plantronics BUA-100 dongle - which was also very very expensive.
883c841.jpg Now the battery is evidently failing - and the 590a's range is getting shorter and shorter.
I do not think that Plantronics has managed this device's roll-out in a competant manner.
Jan 09, 2010 | Plantronics Pulsar 590A Wireless Headset
Technical spec for plantronics C60 headset
Plantronics CS60
Type: Headphone
Acoustic Seal: Sealed/Closed/Sound Canceling
Headphone Frequency Response: Hz
Headphone Sensitivty: 14 dB/1mW dB/1mW
Wireless Technology: Infrared
Battery Time: 9 hours hours
Battery Type: Alkaline
Radio Frequency Range: 1.8GHz
Transmission Range: 100 m.
Compliant Standards: TCO '07
Jan 16, 2009 | Plantronics CS60 Professional Headset
Plantronics Explorer 340 Wireless Headset Logo
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
